Thanks for all the hard work Drod, and was wondering what you were cooking up from your Twitter posts.. Thread is now stickied...![]()
This is a discussion on rubiX Focused 2.0 within the Droid X ROMs forums, part of the Droid X Development category; Thanks for all the hard work Drod, and was wondering what you were cooking up from your Twitter posts.. Thread is now stickied......
I use Quickclock as my overclock and undervolting app. Is there no way to change governors with that? I do have SetCPU purchased but haven't reinstalled it ever since using Quickclock because I was afraid they wouldn't work well together.
Drod.....this is the smoothest rom I have tried since gingerbread on D1. Excellent work man! I may have just found a permanent rom for my X.
I was wondering if there would be any issues between Quickclock and the new governors. I have an overclock set up, but the Quickclock app doesn't actually show the 5% increments that the conservative governor shows, so I was confused as to whether or not it was actually working.
First of all thank you for all your roms. Unfortunately I am running 2.0 since last night and my phone seems to be laggy and at times it freezes. I had been running 1.97 for quite awhile .never had this problem. I will try to reinstall tonight and see if any better. I will however donate for the awesome work and fun we have with these roms.. thank you
So as per requested earlier ill add my thoughts about this rom.
First let me say im not an expert on any of this!
I was running rubix 1.9.7 before switching to liberty 1.5. I don't think much has changed in 2.0. Although I don't think it liked my x upon first install. I had a few force closes and the live wallpaper im using seemed a bit on the laggy side.
Adw was acting weird as I tried to add widgets to the homescreen and i got a force close.
But after a quick reboot and about an hour of playing around it seemed to have smoothed out and has been running pretty good all day. Im still thinking there may be a bug or 2 that may need a bit of tweaking.
The app drawer is a little slow to respond. Not sure if its Adw or the rom itself. I may have to play around with that a bit.
I have no idea how to use the governments and overclocking stuff so ill leave that up to an expert.
Ill be sticking with 2.0 for a while. I do have to say that im a little disappointed in the choices of themes. Im gonna need to check wugs port think he has some rubix themes in there! Hope I was a little help!
~~~**May's X**~~~
