[ROM] ApeX V1.4.0 for Droid X & Droid 2 - Refinement and Ease of Use (2/14/2011)
This is a discussion on [ROM] ApeX V1.4.0 for Droid X & Droid 2 - Refinement and Ease of Use (2/14/2011) within the Droid X ROMs forums, part of the Droid X Development category; Admin edit: NOTE: This Droid X ROM release is for the older Froyo OS. This ROM can only be flashed on Froyo, and is no ...
Page 1 of 80 1 2 3 11 51 ... LastLast
Results 1 to 10 of 797
Like Tree78Likes
Thread: [ROM] ApeX V1.4.0 for Droid X & Droid 2 - Refinement and Ease of Use (2/14/2011)
    Developer
    Developer
    Points: 11,486, Level: 70
    Level completed: 59%, Points required for next Level: 164
    Overall activity: 1.2%
    Fabolous's Avatar
    15069
    168
    193 times
    [ROM] ApeX V1.4.1 for Droid X & Droid 2 - Refinement and Ease of Use (2/22/2011)
    Admin edit: NOTE:This Droid X ROM release is for the older Froyo OS. This ROM can only be flashed on Froyo, and is no longer supported by the dev. please use caution.
    Please see the Gingerbread and Ice Cream Sandwich sub-forums for current, supported ROMs
    Current Toolbox Version: 1.0.6 (2/21/11) - run 'updatetb' to update
    ApeX V1.4.1 for Droid X & Droid 2 - As Blurry or Stock as you'd like. The power is in your hands!
    For Droid X users, you must be on system 2.3.340 already. I think it is safe to assume the overwhelming majority of you already are. There are no additional requirements for Droid 2 users.
    Many common questions about Apex have answers that can now be found at the official Wiki. Please take a look below, thanks!
    Main Page - FabDroid Wiki
    Changes in V1.4.1
    -updated busybox to 1.18.0
    -switched from install-recovery.sh to init.d startup scripts (won't butt heads with apps anymore!)
    -integrated Marius/Imoseyon's startup/cron scripts into my init.d scripts (well, basically kanged them!)
    -Almost 100% certain I fixed nasty startup FC's!
    -Apex mountain wallpaper is now reaccessible through 'Wallpaper Gallery'
    -THX Certified sound is working ;-)
    -Swype is fixed for D2 Version
    -Toolbox update 1.0.6 (cleaner menu drawing, more themes)
    Changes in V1.4.0
    - New Apex Toolbox (Terminal Based) to customize the ROM to the max
    - New Boot Animation (thanks tntdroid!)
    - New Background, Ringtone, Notification Tone (change of pace!)
    - Taller GB Keyboard, same size as MT Keyboard (thanks kejar31!)
    - Removed Data Throttling (thanks droidxchat for an awesome utility!)
    - Core Apps all updated to latest versions (Gmail, ADW Launcher, Market, Search, etc.)
    - Blacked out Google Talk app (ty kejar31!)
    - Fixed Mms.apk w/ Android 2.3.2 routing fixes (won't send to the wrong person!)
    - MusicMod back by default, supports lock screen controls (ty kejar31!)
    - FC @ Startup fixed (no more wait, power, reboot cycle!)
    - Updated JRummy overclocking script (ty JRummy16!)
    - Option to install leaked Motorola "Connected Player" in Toolbox
    - Finally updated the Swype theme to "Blackout" (ty javroch!)
    - A LOT of new features in the Toolbox (services.jar tweaks, goodies downloader, etc.)
    Credits to P3Droid, TBH, Team DeFuse, Xeudoxus, Beesley, Cyanogen, Pete, and many more. Without all the contributions of the devs to the Android community, this would not be possible. Thanks!
    I especially want to thank kejar31 and JRummy16! They've both been very helpful to me to help make ApeX better!
    Features:
    - Optimized & Zipaligned framework and applications
    - Combination of AOSP and Blur apps (customize with Toolbox!)
    - Build.prop and sysctl.conf mods (ty Beesley, nenolod, drod!)
    - Gingerbread Android 2.3 Theme from SDK image
    - Transparent Notification Shade
    - ADW.Launcher with up to 7 homescreens (5 by default)
    - Customizable Neural Network Live Wallpaper from CyanogenMod
    - Built-in ad blocking (toggle with Toolbox!)
    - Google-fixed 2.3.2 MMS app w/ black background (switchable to Blur via Toolbox!)
    - Yahoo! email and corporate sync working (requires switching to Motorola Messaging Suite)
    - Custom window animations and transitions
    - Spare Parts, Terminal Emulator, Wireless Tether preinstalled
    - Many options to customize and make this ROM yours via Toolbox!
    Screenshots
    Toolbox: You can access the toolbox by following these three steps - open terminal emulator, type su and hit enter, type apextoolbox and hit enter.
    You can then navigate the toolbox using the corresponding numbers from the menus!
    Comprehensive guide to the Toolbox will be up in the Wiki within a few days!
    Scripts: There are still a few scripts left. They are as follows:
    apextoolbox : this launches the Toolbox script
    overclock : this launches the overclocking script
    sys : this mounts/unmounts system as read/write
    updatetb : this updates the toolbox against my server
    Installation Instructions: Please have a nandroid of your current setup in case this is not for you
    Users coming from 1.3.1 may be safe to keep data and cache. If there are problems, then factory reset. - Uninstall updates to Market, Gmail, ADW Launcher, & Search if they're there under Settings->Applications->Manage Applications first.
    -Place file on your sdcard. Bootstrap recovery and reboot recovery
    -Select Factory Reset (delete data/cache)
    -Return to previous menu and install .zip from sd card
    -Choose ApeX and install!
    Download Links:
    Droid X V1.4.1
    MD5: d2e2cdc88c2b87a55fee11cd5d568c9d
    Droid 2 V1.4.1
    MD5: 49a729454a52087b452b2aaaab90aec9
    QUIRKS
    - If you're using another launcher besides ADW, do not use the 'Search' widget. That's for ADW only. It'll get stuck at the top of your screen if you use it on LauncherPro. Use the 'Google Search' widget instead.
    - If you add a Yahoo! or Corporate account through the My Accounts app, you will need to use the Toolbox to switch to the Motorola Messaging Suite (MMS & Email)
    Themes:
    Comprehensive list of themes for 1.4.x can be found here:
    Themes For ApeX 1.4.x (2/21/11) - Droid Forum - Verizon Droid & the Motorola Droid Forum
    If you enjoy my work, consider buying me a beer
    Beer Fund | FabDroid
    Points: 38,364, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,091
    243 times
    Cool was waiting on Twitter for this. I ran the RC all day flawless Fab outstanding work.
    DrivetheGreen66
    Guest DrivetheGreen66's Avatar
    This is the first time I'm going to run Apex. Looking forward to it.
    Points: 4,824, Level: 44
    Level completed: 37%, Points required for next Level: 126
    scottpole's Avatar
    27229
    1,118
    38 times
    Dling now. Gonna jump right into this one
    Uploaded from my Blurry X ~_~
    Warm Gingerbread with super user icing
    Points: 2,852, Level: 32
    Level completed: 68%, Points required for next Level: 48
    Overall activity: 0.7%
    idontliketolose's Avatar
    19321
    426
    18 times
    Nice!
    Sent from the VorteX!
    Points: 9,746, Level: 66
    Level completed: 24%, Points required for next Level: 304
    Overall activity: 11.7%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,079
    64 times
    Great work as always
    My X has been orangesliced!!
    Points: 40,759, Level: 100
    Overall activity: 13.1%
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,330
    786 times
    Apex noob here. Downloading now.
    Points: 1,555, Level: 22
    dirtyfingers's Avatar
    26573
    Wisconsin
    125
    Sweet, I'm gonna give this one a shot. HDMI should be functional in this correct?
    Liberty 1.5, WatermarkD Theme, Black Market, OC'd 1.2 GHz
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,079
    64 times
    Yeah should
    250 Experience Points31 days registered100 Experience Points7 days registered
    sunrat39's Avatar
    25109
    60
    Ok I like how this rom has a lot of blur elements as well like the HDMI and DLNA but I don't know how I would be able to use the HDMI function when the BLUR gallery is not there? Anyone?
  1. Droid x 2.2.1 rooted with apex 1.3.1
    By camten19 in forum Droid X Rooted Issues
    Last Post: 01-29-2011, 01:20 PM
  2. Droid X coming in mail 1/3/2011
    By preciado209 in forum Droid X General Discussion
    Last Post: 12-29-2010, 12:35 PM
  3. Apex 1.3 and Droid X Overclock help
    By nickbutterz in forum Droid X General Discussion
    Last Post: 12-14-2010, 09:58 PM
  4. Droid X - End of life is here - March 31st, 2011
    By DebianDog in forum Droid X General Discussion
    Last Post: 08-25-2010, 04:11 PM
  5. Ease On Down the Road
    By BukowskiSoul in forum New Member Introductions & Site Assistance
    Last Post: 07-30-2010, 05:50 PM
apex d2 rom
apex droid x
apex rom d2
apex rom for droid x
apex toolbox busybox not found
droid x 4.0
droid x 4.0 rom
droid x apex
droid x forums roms
droid x rom
droid x rom list
droid x roms
droidx roms
forum rom list droid x .zip
vortex rom droid x
