This is the first time I'm going to run Apex. Looking forward to it.
This is a discussion on [ROM] ApeX V1.4.0 for Droid X & Droid 2 - Refinement and Ease of Use (2/14/2011) within the Droid X ROMs forums, part of the Droid X Development category; This is the first time I'm going to run Apex. Looking forward to it....
This is apex for the froyo kernal, just fyi.
Also, if memory serves me, this will prompt you to add email account information (not Google but other) this is the blur accounts and not compatible with the AOSP email that is provided. Just remember to add your email account info through the email program. Its been a while bit I specifically remember this being confusion foe many in apex 1.4
Went to apply Apex ROM for the first time. Bootstrapped into recovery mode, wiped cache/user data/factory reset and applied Apex. On reboot it just hangs on the M logo.
Had to flash back with RSD lite 5.55 to the 602.sbf to get it completely back to stock so I could even boot again. Rooted the phone again via Pete's Root Tools, started over again and flashed Apex.... same thing.
When I reboot it just hangs on the M again. :\
Any ideas?
You're on Gingerbread and this version of Apex is for Froyo. You want Apex 2.0 RC4.
[ROM][DROIDX] ApeX 2.0.0 Release Candidate (RC4) (10/9/2011)
on the move..
Need more help? Click above ^
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
Android Dictionary
Froyo to Gingerbread
Ugh... /newb
Thank you, sorry for the bother.![]()
Haha no bother at all, glad to help.
on the move..
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
Android Dictionary
