Yes, there is. The "Remove Clock From Notification Bar" in ROM Manager works. Just choose the one for black bars. Or you can get it here:
[MOD] Remove Clock in Notification Bar - Android Forums
In the DarkSlide thread over at MDW, this is where people are being directed to go to get the mod.
02-12-2011 02:31 PM
I've installed Dark Slide 4.2 from the first page but my phone shows it to be 4.1. Any suggestions?
Any improvements in performance over earlier versions?
I can't really tell any difference.
Originally Posted by
Carpetman
That was brought up on the other forum. It was a typo on the full rom. The notification pulldown should say 4.2 though. And the menu options should all be transparent. If they're solid colors, then its 4.1.
Sent from DarkSlide 4.2
Liberty wasnt the first rom to do that either.. Tranq was.. There is NOTHING new about liberty other than the fact the mods have to be downloaded other than built into the rom. Oh liberty was the first yellow rom.
DebianDog
Im not able to download any roms. I click the download link and all of them come up as page unavailable
What is the difference between blur and blurless?
What would be the advantage of one over the other?
Thanks for any help!
stickjohnsonaah
I was told to get the Dolphin Browser from the market and use it to download and I did and now I have no trouble downloading. Hope this helps.
The M boot logo will hang on but the bootanimation will be wiped , you will have to flash a new M logo or in the case of liberty logo you will have to flash a new M logo replacement . there are allot of pics out there and even the stock M logo
Rooted OClocked DROIDX Rootedthemed Bionic
