[ROM] ApeX 1.3.0 for Droid X - Running, running, as fast as it can
This is a discussion on [ROM] ApeX 1.3.0 for Droid X - Running, running, as fast as it can within the Droid X ROMs forums, part of the Droid X Development category; Running awesome..digging the animations! One quick question about ADW, maybe you can help, I accidentally dragged an app onto the launcher button thinking it was ...
Page 2 of 84 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 833
Like Tree82Likes
Thread: [ROM] ApeX 1.3.0 for Droid X - Running, running, as fast as it can
    happydroid's Avatar
    1048
    Rialto, CA
    34
    Running awesome..digging the animations! One quick question about ADW, maybe you can help, I accidentally dragged an app onto the launcher button thinking it was going to remove it off the homescreen. Instead it stayed on. How can I switch the shortcut back to the launcher button?
    rubiX Focused 1.9.7 - 1.1 Ghz
    Follow me on Twitter--@theoriginalvic
    Developer
    Developer
    Points: 13,682, Level: 76
    Level completed: 8%, Points required for next Level: 368
    Fabolous's Avatar
    15069
    168
    193 times
    Yeah, the trash is up top now
    To make the launcher shortcut, press menu, add, custom shortcut, pick activities, launcher activities, open app drawer. Then you can drag the shortcut back down.
    happydroid's Avatar
    1048
    Rialto, CA
    34
    Quote Originally Posted by Fabolous View Post
    Hooray!!!!
    phr00t's Avatar
    20026
    5
    Big fan of ApeX 1.3.0, thanks!
    I was using ApeX 1.2.1 w/ .320 leak. I used the SBF to upgrade to .340, and then upgraded to ApeX 1.3.0 without formatting data -- and all upgraded perfectly!
    A+++++ WOULD FLASH AGAIN!!!!!!!
    Xdaddy's Avatar
    18302
    Mason City, IA
    12
    downloading now.... running traq 3.6 but i dont like that the market crash's and the calendar widget doestn work ;(... ill retore my stock backup and give this badboy a whirl right now
    StephenX's Avatar
    16661
    77
    Any reason to switch to this from Rubix 1.9 if it's running smoothly? I ran Apex before, but left because of the reboots.
  8. #17
    Points: 2,485, Level: 30
    Level completed: 24%, Points required for next Level: 115
    250 Experience PointsCreated Album pictures100 Experience Points31 days registered7 days registered
    BadMedicine's Avatar
    9633
    Charleston, SC
    213
    As soon as yall get acquainted with this ROM I really would like to know how the battery life is while running this on the new update. I'm going to hold out until I get some more feeback and more ROM's become available.
    Droid X Rooted (OTA 2.2.1) Liberty ONE Point O Overclocked at 1.2Ghz LV
  9. #18
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    MrSniffles69's Avatar
    3052
    137
    AWESOME THANKS!!
    I am now rooted and downloading the ROM as I type lol.. I will be donanting to your fund tomorrow when my paycheck comes in!!
    Just few more questions.. Can you explain this whole script thing and exactly how to use it and how it works thanks man!!
    in terminal:
    su
    gallery -mot
    and for future reference, you can type just about any of the scripts in the first post without the modifier at the end (i.e. -mot) and it'll print out the correct usage (all the options, and what they do)
    First, go into settings, and confirm that you are on build 2.3.340 and Android version 2.2.1. If that's all good, then go here:
    [APP] z4root - xda-developers
    and get z4root, which is a 1-click rooting app that works on the new OTA.
    Then, download Droid X Bootstrapper from the market, click bootstrap recovery, reboot into recovery, backup/restore, backup.
    Once you reboot back into android, you can follow the steps in the first post to install this ROM.
  10. #19
    BringTherain403's Avatar
    498
    52
    Are we able to do an advanced restore in nandroid and just install the system so I don't lose all my data and settings from my stock rooted .340 update?
  11. #20
    Points: 2,665, Level: 31
    Level completed: 44%, Points required for next Level: 85
    lifebeginsfriday's Avatar
    4332
    Virginia
    155
    Download down? Failed...
    DX - Apex 1.3 - OTA 2.2.1 - And loving it!. I-What!!!
  1. Droid X running hot. Anyone else?
    By ssmorris in forum Droid X General Discussion
    Last Post: 11-11-2010, 05:47 PM
  2. unroot droid x running 2.2
    By heartlandex in forum Droid X General Discussion
    Last Post: 10-26-2010, 02:48 PM
  3. Droid X pics running 2.2
    By C-had in forum Droid X General Discussion
    Last Post: 07-28-2010, 02:40 PM
  4. Anyone running Droid X Slingbox APP yet?
    By DoctorB in forum Droid X Audio / Video
    Last Post: 07-14-2010, 03:31 PM
  5. Droid X running Slimgbox app out there yet?
    By DoctorB in forum Droid X General Discussion
    Last Post: 07-14-2010, 03:29 PM
apex droid x
apex droid x rom
apex for droid x
apex rom droid x
droid x apex
droid x apex rom
droid x rom
droid x roms
fastest droid x rom
roms for droid x
