Importing outside MP3's into DX for ringtones
This is a discussion on Importing outside MP3's into DX for ringtones within the Droid X Ringtones forums, part of the Droid X Audio / Video category; Is it possible to import/download MP3's into and assign them as ringtones on my DX? And if so, How. I've tried everything I can think ...
Results 1 to 8 of 8
  • 1 Post By skennelly
Thread: Importing outside MP3's into DX for ringtones
    U.S. Male's Avatar
    4835
    Queens NY
    26
    Is it possible to import/download MP3's into and assign them as ringtones on my DX? And if so, How. I've tried everything I can think of already. So if it is even possible I'l need the 'For Dummies' version.
    I'm only smiling on the outside
    My smile is just skin deep
    If you could see inside, I'm really crying
    You might join me for a weep
    Points: 3,129, Level: 34
    Level completed: 53%, Points required for next Level: 71
    Overall activity: 0.7%
    kirbnite's Avatar
    29262
    312
    26 times
    Not entirely sure I understand completely, but here is my best answer.
    I had the original droid before I got the droid x. In order to use media from my memory card, I had to create a folder called media, then in media, create 3 folders. (ringtones, alarms, and notifications). In those folders put the media you would like to use.
    My droid x, allows me to choose music as a ringtone and I did not put it any where special.
    Also, if you would like to use a mp3 from the media card then I strongly recommend downloading, ring droid from the market.
    U.S. Male's Avatar
    4835
    Queens NY
    26
    Thanks for the hasty response. I will try this and get back to you.
    Points: 7,344, Level: 56
    Level completed: 97%, Points required for next Level: 6
    Overall activity: 7.3%
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    just long press on the mp3 file in your playlist and a menu will appear with the option to use song as ringtone.
    Sent from my DROIDX in Western Illinois
    MEGA MAN likes this.
    I'm having a big prob with getting my mp3 file to play as my ringtone. Got ringtone from Verizon themselves. File is visible and have designated it as my ringtone no problem. However, the player says doesn't recognize the file format. WTF? I bought the file from Verizon. ??? Any suggestions?
    Points: 1,286, Level: 19
    Level completed: 86%, Points required for next Level: 14
    RHV's Avatar
    8015
    7
    use Ringdroid and you can chop up mp3 on your phone into ring tones
    Moderator
    Points: 8,610, Level: 62
    Level completed: 54%, Points required for next Level: 140
    Overall activity: 95.4%
    maybish's Avatar
    20852
    new jersey
    2,834
    70 times
    +1 for ringdroid! ive used it, works pretty good!
    Points: 1,223, Level: 19
    Level completed: 23%, Points required for next Level: 77
    Overall activity: 8.8%
    Bruincat's Avatar
    32848
    Upstate N.Y.
    36
    Quote Originally Posted by RHV View Post
    This ^
  1. Using downloaded app (ringtones) as ringtones
    By kwhiteley in forum New Member Introductions & Site Assistance
    Last Post: 12-29-2010, 02:57 PM
  2. Importing Contacts (email address) Issue
    By crashintome in forum Droid X Help
    Last Post: 12-04-2010, 02:05 PM
  3. importing pictures?
    By redwinger2001 in forum Droid X FAQs
    Last Post: 11-28-2010, 11:03 AM
  4. Importing Contacts to Google with no SD card
    By shamy in forum Droid X Help
    Last Post: 08-25-2010, 01:13 PM
  5. importing the droid phone book to the car
    By ravis in forum Droid X General Discussion
    Last Post: 08-09-2010, 02:00 PM
droid 4 import ringtones
droid 4 ringtone import
droid import ringtones
dx is ringtones dx is ringtones dx is ringtones download now
how do i import a ringtone to droid x
how to import mp3 as a ringtone on android
how to import mp3 as ringtone to android
how to import mp3 ringtone to droid
import rimgtone android
import ringtone android
import ringtones into android
import ringtones to droid x
importing ring tones on android phone
importing ringtones into android
importing ringtones to android
