gmail not syncing.... again...
This is a discussion on gmail not syncing.... again... within the Droid X Rescue Squad forums, part of the Droid X Discussion category; so in 2.1, there was a menu if you went to gmail>accounts>account settings. under that, there were a couple of options but one of them ...
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 72
Like Tree7Likes
Thread: gmail not syncing.... again...
    f3liC's Avatar
    6199
    45
    so in 2.1, there was a menu if you went to gmail>accounts>account settings. under that, there were a couple of options but one of them was "auto sync gmail" or something along those lines. now with the ota 2.2 update, i can't find that menu anymore nor is my gmail autosyncing anymore. does anyone know where that menu went?
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,818
    138 times
    Moved to correct sub-forum
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Backnblack's Avatar
    26
    2,818
    138 times
    have you tried Settings>>Accounts>>Gmail Account....whats checked?
    2. See Rule #1
    f3liC's Avatar
    6199
    45
    if i go to settings>accounts>gmail acc, it says "sync contacts", "sync gmail" , and "sync" calendar but i don't see an auto sync option. those 3 options are for manual sync no?
    Points: 71,075, Level: 100
    Overall activity: 29.5%
    20,495
    876 times
    Quote Originally Posted by f3liC View Post
    I do not think it means these are for "manual sync" but you can manually sync them from this screen. If these items are checked, they will sync as background data at specific intervals (I have never been able to find a setting to determine that interval)...the auto sync function thru the gmail app was eliminated in the 2.2 update - not sure why, all we can do now is view how the data is delivered to the phone...
    Before 2.2, there was suggestions where you could log into the YouTube app on the phone with your gmail account (either one you were trying to add or one that was not syncing) and for some unknown reason, it would add / sync...you might try that to see if it helps with the sync...
    Guidelines of Conduct for DroidXForums.com
    f3liC's Avatar
    6199
    45
    under the screen you're talking about, there are no checkboxes. they're all touch to sync
    20,495
    876 times
    So in the phone settings - accounts - google - there are not 3 boxes to check / uncheck...if you hit the hard menu key here - does it give you any options...
    f3liC's Avatar
    6199
    45
    nope no boxes to check under settings>account>gmail. menu key just gives the options to sync contacts, gmail, and calendar.
    20,495
    876 times
    Go into gmail - menu key - accounts - data delivery - what is checked there? Did you try logging into "youtube" to see if that would sync?
    The removal of the checkmarks must be a change from the leaked 2.2 to the OTA 2.2...I will post a screenshot so you know I am not crazy LOL...
    Points: 2,741, Level: 31
    Level completed: 94%, Points required for next Level: 9
    Pensacola32526's Avatar
    6225
    Pensacola, FL
    296
    You're not crazy, I have the same problem...
    Still my , even after so many SBFs, ROMs, battery pulls and Clockwork recoveries...
    Rooted, Gingerbread .602, VorteX RC1, Trident Electra & 3200 mAh battery.
    USMC 2000-? Oorah!
  1. Replies: 4
    Last Post: 10-19-2010, 07:29 PM
  2. Gmail Contact Group syncing with 2.2?
    By Perm in forum Droid X Help
    Last Post: 09-22-2010, 10:54 AM
  3. gmail contact sync issue - only 1% syncing?
    By brtnrydr in forum Droid X Help
    Last Post: 09-08-2010, 07:40 PM
  4. Gmail email stopped syncing on Droid X with 2.1
    By luckyzu in forum Droid X Help
    Last Post: 08-23-2010, 11:30 AM
  5. Gmail syncing problems
    By coasterman93 in forum Droid X General Discussion
    Last Post: 07-17-2010, 06:01 PM
Droid pro not syncing contacts
Gmail won't sync on droid x
android 2.3 gmail not syncing
droid pro contacts not syncing
droid x gmail not syncing
droid x gmail won't auto sync
droid x won't auto sync
droid x wont auto sync
gmail not syncing droid x android 2.3
gmail wont auto sync droid x
