HELP!! Droid X .621 needs battery pull for every power on
This is a discussion on HELP!! Droid X .621 needs battery pull for every power on within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Ok, so I was having problems with my WIFI, so I decided to take the OTA .621 update, and see if that helped. I took ...
Thread: HELP!! Droid X .621 needs battery pull for every power on
    Points: 1,192, Level: 18
    Level completed: 92%, Points required for next Level: 8
    foreverbmw's Avatar
    46143
    Aug 2011
    Ok, so I was having problems with my WIFI, so I decided to take the OTA .621 update, and see if that helped. I took the update, then did a factory reset, and used the Droid X ezsbf & root ISO to root the device. Now every time I power the phone off, and power back on, it gets stuck on the moto M screen. If i do a battery pull and re-insert battery, the phone will boot up fine. However, the next time I power off, and power back on, the same thing happens! I tried SBFing with the CD to .621 again, and doing another factory restore, this time without root, and the same thing happened? What is going on? Should SBFing have put me back in factory state ??
    Thanks for the help!
    Points: 2,503, Level: 30
    Level completed: 36%, Points required for next Level: 97
    Overall activity: 5.9%
    250 Experience Points31 days registeredCreated Album pictures100 Experience Points7 days registered
    droidx2.3.3's Avatar
    40364
    242
    If you did an sbf, yes that should have pit you to like out of the box new state. What I would try next is, sbf again then do a factory reset on the first reboot after the sbf. Then see if that helps any.
    Points: 18,189, Level: 85
    Level completed: 68%, Points required for next Level: 161
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    no errors on the bootloader screen?
    Sent from my MILESTONE3 using Droid X Forums
  1. Replies: 2
    Last Post: 02-03-2013, 02:48 PM
  2. Replies: 16
    Last Post: 10-17-2011, 06:49 PM
  3. My Droid X will not power on unless 15% battery
    By borostang in forum Droid X General Discussion
    Last Post: 03-03-2011, 02:07 PM
  4. RED battery pull tab
    By MJC in forum Droid X General Discussion
    Last Post: 09-04-2010, 02:12 AM
battery reset for droid x
droid x framaroot .621
droid x needs battery pull to boot
how to reset droid x with 621
