Droid X - Cannot Do Default Factory Reset (NO Home+Power)
This is a discussion on Droid X - Cannot Do Default Factory Reset (NO Home+Power) within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I have a bit of an issue, I have my Droid X that freezes on the Red Eye when booting. I cannot get to the ...
Results 1 to 6 of 6
Thread: Droid X - Cannot Do Default Factory Reset (NO Home+Power)
    Points: 1,342, Level: 20
    Level completed: 43%, Points required for next Level: 58
    Overall activity: 0.8%
    BuckNaked78's Avatar
    25858
    I have a bit of an issue, I have my Droid X that freezes on the Red Eye when booting. I cannot get to the Factory Reset mode because my home button is stuck down or it just doesn't work anymore. The other buttons around it work fine. So I went on reading and decided to flash it using the sbf method; although I tried many times it seem to fail no matter which sbf version i used. After failing it would give me the boot loader error:
    Bootloader
    30.04
    Err:A5,70,70,00,1F
    MEM_MAP Blank
    Service Req'd
    Battery OK
    OK to Program
    Transfer Mode:
    USB
    I recently was able to get the 1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf to reboot and start to actually boot instead of the Error screen above. It is now stuck in the boot loop. Any thoughts how I can fix this issue with our needing to use the Home key?
    Points: 8,788, Level: 63
    Level completed: 13%, Points required for next Level: 262
    Overall activity: 99.6%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,055
    125 times
    Are you doing the sbf with a motorola cable? It matters, a generic cable doesn't work very well for sbf, as for the button, you may be able to fix it if it's stuck but I have never taken mine apart so I don't know.
    Pimped out Dx WiZaRdS MiUi
    25858
    Yes, I have used a few different Motorola cables; along with different PC's. I have not tried the Linux method yet (here). I took it apart but was unable to get to the keys as I do not have a size 3 torx or hex screwdriver.
    Also, the Status of the last Flash using RDS Lite reads "Please Manually power up this phone."; it is currently in the boot loop.
    Points: 17,977, Level: 85
    Level completed: 26%, Points required for next Level: 373
    Overall activity: 99.8%
    6,245
    138 times
    The mem pack blank error on your bootloader means you are on. 621. You have to use the 621 SBF file, you can't use older versions.
    Edit: yea shoulda finished reading the post, my bad.
    Sent from my X2 using DXF
    Points: 7,205, Level: 56
    Level completed: 28%, Points required for next Level: 145
    Overall activity: 28.1%
    1,340
    78 times
    The boot loop post SBF means you need to wipe data/cache in recovery.
    Sent from my SCH-I535 using Xparent Red Tapatalk 2
    25858
    I kind of figured that, but I cannot access the correct screen because the Home button does not work. How can I correct this? I do not have the right torx screwdriver to remove the screen to access the buttons. Any thoughts?
    Also, I plan on ordering a new tool set with said torx screwdriver soon.
  1. Droid X still reboots even after a Factory reset
    By JCizzle93 in forum Droid X Help
    Last Post: 10-03-2012, 08:19 PM
  2. Factory reset a rooted Droid X2?
    By theguru1974 in forum Droid X2 Hacks
    Last Post: 06-25-2011, 09:24 PM
  3. Replies: 14
    Last Post: 05-17-2011, 10:13 PM
  4. DROID X - Factory Data Reset
    Last Post: 07-15-2010, 02:06 AM
Droid X will not factory reset
droid x factory reset no service
droid x no service after factory reset
droid x recovery without home button
droid x will not reset
droid x wont hard reset
factory reset droid x, no power button, boot looping
factory reset motorola droid x with no home key
how to reboot droid x
reset droid x
