Bootloader 30.04 err:a5,70,70,00,1f new map_blank servic req'd battery low cannot pro
This is a discussion on Bootloader 30.04 err:a5,70,70,00,1f new map_blank servic req'd battery low cannot pro within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Cannot program. I am new at this and I tried to root my phone using this method; http://wiki.cyanogenmod.com/wiki/Motorola_Droid_X:_Full_Update_Guide I got to step 10 where it ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Bootloader 30.04 err:a5,70,70,00,1f new map_blank servic req'd battery low cannot pro
    Points: 324, Level: 6
    Level completed: 48%, Points required for next Level: 26
    firehouse141's Avatar
    61049
    Aug 2012
    9
    Cannot program.
    I
    got to step 10 where it said to pull battery. Instead I got the message;
    Bootloader 30.04
    err:a5,70,70,00,1f
    new map_blank
    servic req'd
    battery low
    cannot program
    I plug it into the wall it stays that way. I plug into USB and it turns off after a minute. And the other problem is that my computer will not recognize that the phone is plugged in. I have a Windows 7.
    Points: 18,299, Level: 85
    Level completed: 90%, Points required for next Level: 51
    Overall activity: 97.8%
    6,302
    139 times
    Were you on .621? And was your battery fully charged before you tried to SBF?
    61049
    Aug 2012
    9
    I am not sure. I used RSD lite 5.7. Like I said I am new at this so there is a grip I do not understand.
    Thank you for the quick response.
    61049
    Aug 2012
    9
    And no it was not fully charged. A little bit over half.
    Points: 4,203, Level: 41
    Level completed: 27%, Points required for next Level: 147
    Overall activity: 5.6%
    towbiz's Avatar
    41404
    1,095
    23 times
    If your phone will function go to settings/about phone/ and see what system version your on
    61049
    Aug 2012
    9
    my phone will not function at all. It is stuck on this screen. I also tried pressing home and power at the same time.
    towbiz's Avatar
    41404
    1,095
    23 times
    Well first thing is your battery is too low to fix it right and stuck in bootloader it wont charge so you need a way to charge it first
    Points: 7,321, Level: 56
    Level completed: 86%, Points required for next Level: 29
    Overall activity: 24.2%
    1,341
    78 times
    That message only appears if you trip the efuse, meaning the signature on the CDT partition failed and was wiped.
    Most common cause is you were on 621 and tried reverting to an earlier build. What SBF file did you flash? When was the last time you got an OTA update?
    Sent from my jellybeaned AOKP GSIII
    61049
    Aug 2012
    9
    This is what I flashed;
    Download the Motorola Drivers, RSD Lite & the 2.3.340 firmware:
    • RSD Lite 5.7: Downloadmd5: feb9a71470ee539e074bf420a2e4d8bd
    • Motorola 5.5.0 device drivers: Download
    • 2.3.340 firmware: Downloadmd5: 48c0d5cb3805497a6cbaf120dfb63002
      So if my battery won't charge. can I take it into Verizon or will I need a new battery?
    I did update my phone a couple of months ago.
    Also, my computer wont recognize that the phone is plugged in anymore. Will this fix with a fully charged battery?
    Points: 487, Level: 9
    Level completed: 74%, Points required for next Level: 13
    Overall activity: 3.3%
    scuzzo's Avatar
    58722
    May 2012
    42
    You really need to order a new battery. I've found them as cheap as $1 on Amazon. I had this exact problem when I tried to root my dx the first time. I left it plugged in overnight and still no love. Ordered a new battery and it gave me the time to fix it. And I can attest that these phones are almost unbrickable. Post back and we will help.
  1. Bootloader 30.04 Battery Low Cannot Program
    By gunnyz39 in forum Droid X Rooted Issues
    Last Post: 11-23-2012, 11:54 AM
  2. Bootloader 30.04 Battery Low Cannot Program
    By ezek413 in forum Droid X Help
    Last Post: 11-16-2012, 12:55 PM
  3. Replies: 6
    Last Post: 01-19-2012, 04:41 PM
  4. HELP!! Battery/Bootloader Issues!!!
    By calais79 in forum Droid X Help
    Last Post: 02-13-2011, 03:37 PM
  5. Dead Battery and BootLoader?
    By z.snafu in forum Droid X Hacks
    Last Post: 09-07-2010, 11:29 PM
bootloader 30.04 err:a5,70,70,00,00 droid x
bootloader 30.04 err:a5,70,70,00,1f sbf 621
bootloader err a5 70 70 00 1f cannot program
bootloader err a5 70 70 battery low
droid 2 global stuck in bootloader and wont charge
droid x not showing in rsd lite err:a5,70
err: a5,70,27,00,1f battery low cannot program
motorola d0.11 err:a5, 70, 00, 1f
motorola droid 2 global battery low cannot program
???????? ?????2 err:a5, 70, 00, 1f
