Soon to be in possession of project phone - Questions
This is a discussion on Soon to be in possession of project phone - Questions within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Did you do a factory reset after? Home and power then both volume buttons> scroll to wipe data with the volume button> select it with ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
Thread: Soon to be in possession of project phone - Questions
    Points: 41,311, Level: 100
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    13,640
    162 times
    Did you do a factory reset after? Home and power then both volume buttons> scroll to wipe data with the volume button> select it with power button> then do the same for cache then reboot...try that first
    tap'd from the Gnex
    Points: 135, Level: 2
    Level completed: 70%, Points required for next Level: 15
    Overall activity: 3.7%
    100 Experience Points7 days registered
    bridgford's Avatar
    60577
    Jul 2012
    Lansing, Michigan area
    When I reinstalled the battery, it went right back to the bootloader 30.04 screen, as quoted in my previous post. It seems to be the recurring pattern with this phone.
    In prior attempts, I have gotten the red Motorola symbol, but it never got past that screen.
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    Try holding home and power while you put the battery in. If you get the Moto logo keep holding them another 3-5 seconds. Phone should go to a screen with an android and a ! In a triangle. Then both volume buttons pressed simultaneously opens stock recovery as stated above.
    Sent from my Black Iced X
    bridgford's Avatar
    60577
    Jul 2012
    So, taking the battery out for 10 to 15 minutes and puttting it back in launches the screen: "Bootloader 30.04; Battery OK; OK to Program; Connect USB Data Cable".
    Then Power and Home button simultaneously gives the red Motorola M where it seems to stay. Non-responsive except for battery pull at this point.
    Any ideas?
    newmanx4's Avatar
    34469
    703
    27 times
    If you're holding power and home continuously after the logo and nothing's happening you might need to try another SBF maybe with an older version of RSD Lite. I use 5.4.4 I believe it is and its never given me any trouble.
    bridgford's Avatar
    60577
    Jul 2012
    Any chance the battery could be an issue. I bought a battery off of an Amazon vendor and it was swollen. You can spin it like a top on a flat surface. They are sending me a new one, they say.
    I get the same result with RSD Lite 4.8 and 5.7, two different USB cables, two different ports. That all seems to go smoothly and successfully and after the process is through, the phone reboots and goes to "Bootloader 30.04; Battery OK; OK to Program; Connect USB Data Cable". This same screen is what was shown on the ebay listing.
    I thought it would be easier than this...
  8. #17
    Points: 7,198, Level: 56
    Level completed: 24%, Points required for next Level: 152
    Overall activity: 28.3%
    1,340
    78 times
    Quote Originally Posted by bridgford View Post
    Well without a battery that is charged the phone won't SBF. I won't throw that out as an issue (it could be causing voltage spikes as its bloated which could be causing issues) but the phone can't charge in bootloader mode (the green LED indicates it is ready to program and the USB is connected, not charging). But it would be a rarity for the battery to be causing the issues.
    For RSD Lite I have always used 5.4.4. when I used it as above, so I would suggest downgrading to that, and do a clean install of it all, including the Moto USB drivers just to make sure. And of course make sure the USB is being plugged directly into a home USB port, and not a 3.0 port (needs to not be on a hub and needs to be a 2.0 port). Prior to starting the SBF, get it hooked up in bootloader, go to your Control Panel (on PC) -> System -> Hardware and make sure you don't have any missing drivers (Yellow exclamation points) related to the USB ports, or Motorola interfaces. RSD Lite can show a success even if its not (it really is a very finicky program)
    Failing that I would attempt an SBF to .605 using the 1KDS ISOs. If part of the SBF took to .621 there is a chance it might not be able to SBF using one of these discs (you may get an error that says "MEM_MAP Blank" in bootloader) but at least then we can rule out whether or not the phone is taking the SBF (hardware issues on the phone itself). I know you wanted to go to .621 but if we can even get it booting in .605 then you could always OTA to .621 if you really wanted it.
  9. #18
    bridgford's Avatar
    60577
    Jul 2012
    First, thanks for the replies. I did try 605 and got the error mem_map things others have commented on, so it is taking something. I am recharging the battery and going to try the Linux route. Which brings me to the question: is the command line open in a DOS-type window. I'm using Ubuntu 12. Other files are on a flash drive.Thanks
  10. #19
    1,340
    78 times
    Pretty much yes they are DOS-type. If you are on Ubuntu 12 I assume you haven't reverted to Gnome just pull up a terminal window. Make sure you download sbf_flash command and the .621 SBF (as you already have) since there is no linux ISO for it. Run the commands as needed. If you need help running the SBF commands and terminal commands I can provide guidance as needed.
    sbf_flash util:
    https://www.google.com/search?sugexp=chrome,mod=8&sourceid=chrome&ie=UTF-8&q=sbf_flash
    I won't link it directly as we have certain restrictions here for that type of stuff, but its the top hit on the above link if you don't have it already.
  11. #20
    bridgford's Avatar
    60577
    Jul 2012
    Goose,Thanks for all of your help and explanations. I've got the sbf_flash utility. My current main question is how do you open the terminal window. I just booted from the cd and didn't see anything "terminal-like".
    EDIT: Nevermind, I found it. Now for the battery to finish recharging.
  1. Sense project
    By Enyo in forum Droid X General Discussion
    Last Post: 02-26-2012, 10:54 PM
  2. [Project] Android 86x
    By Nemo aeternamn in forum Off-Topic Discussion
    Last Post: 09-17-2011, 12:53 AM
  3. Rom project elite!
    By kvnm8503 in forum Droid X ROMs
    Last Post: 06-27-2011, 07:39 PM
  4. A new project. Help :)
    By jloya in forum Droid X Hacks
    Last Post: 02-28-2011, 02:25 PM
  5. Project Inf
    By Montu in forum Droid X Games
    Last Post: 08-06-2010, 12:31 AM
how to flash sbf files with ubuntu 12
milestone x sbf generic 604
now rsd lite 5.8 2012 download
rsd lite 5.7 errors droid x
rsd lite 5.8
ubuntu milestone x sbf 604
