Droid x bootloop after storage space low error, cant get into CWM
This is a discussion on Droid x bootloop after storage space low error, cant get into CWM within the Droid X Rescue Squad forums, part of the Droid X Discussion category; So last night I got the storage space low error, which has happened before and I usually fix by using terminal emulator to delete the ...
Thread: Droid x bootloop after storage space low error, cant get into CWM
    So last night I got the storage space low error, which has happened before and I usually fix by using terminal emulator to delete the offending tombstone file but before I got a chance to my phone died. When I plugged it in and rebooted it started bootlooping. I can still enter bootloader and stock recovery but not clockwork. Im running CM7 on froyo not sure what version or whatever. My main question is: Do I absolutely have to wipe data/factory reset? Tbh I dont think I saved my last nandroid onto my SD and even if I did I'm pretty sure its a really old one (I know, my fault for not backing up more often.) Is there anything I can do through the bootloader maybe? I really don't want to go through a wipe or an sbf =/ I have recorded music and writing on the phone that I don't have anywhere else and would hate to lose.
    Thanks
    Points: 7,324, Level: 56
    Level completed: 87%, Points required for next Level: 26
    Overall activity: 24.2%
    1,341
    78 times
    Quote Originally Posted by Opera View Post
    Thanks
    Do you have adb working? If so you may be able to get into CWM that way, otherwise its time for an SBF
    Sent from my CM10 GSIII
    What is adb?
    EDIT: Okay so I got a guide off xda for adb installation and I'll give it a go. Any information about adb would be much appreciated since this is new territory for me, thanks.
    UPDATE: So I got adb working, used the shell to access CWM recovery, made a backup after deleting the tombstone, SBF'ed and began running z4 to re-root, when it started again. Except this time it just hangs on the motorola logo now. Any suggestions how to fix this new problem?
  1. Low on Space Error
    By rjs625 in forum Droid X Rooted Issues
    Last Post: 06-11-2012, 07:12 AM
  2. How To Fix The Insufficient Space Error
    By jasonsc1 in forum Droid X Help
    Last Post: 12-21-2011, 11:03 AM
  3. 'App Storage Space' confusion..
    By Ender in forum Droid X General Discussion
    Last Post: 12-19-2011, 01:50 PM
  4. Storage Space
    By Divey1130 in forum Gingerbread Help
    Last Post: 09-16-2011, 09:32 PM
  5. newbie question about video recording/storage space
    By Basher1970 in forum Droid X Help
    Last Post: 04-05-2011, 11:40 AM
droid storage space low
droid x boot loop
droid x bootloop
droid x low on space
droid x low on space error
droid x low on space reboot
droid x low storage
droid x low storage space
droid x storage low
low on space droid x
