Droid X Screen Flicker Issue - Once And For All
This is a discussion on Droid X Screen Flicker Issue - Once And For All within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Hi. I own a Droid X, and like a lot of people, the bottom third of my display started to flicker. Now, over the last ...
Results 1 to 9 of 9
Thread: Droid X Screen Flicker Issue - Once And For All
    Points: 1,641, Level: 23
    Level completed: 41%, Points required for next Level: 59
    1 year registered3 months registered31 days registered100 Experience Points7 days registered
    Gynotai's Avatar
    39624
    San Jose, CA
    11
    Hi.
    I own a Droid X, and like a lot of people, the bottom third of my display started to flicker. Now, over the last couple of months all of the screen with the exception of like 1/2" on the top is so intermittent it's hit or miss as to whether I'll be able to use it for anything.
    I've seen a lot of posts on this topic, but nothing definitive as to what the problem is, or what (short of replacing the phone) can be done to correct the problem.
    Most of the posts regarding this issue are over two years old and the only actual solution then was to go back to Verizon and get the phone replaced; something that I'm confident by now is not an option anymore.
    It's obvious that this is a much larger problem than either Verizon or Motorola would ever admit to, and it's a shame that anyone who has this issue with their phone now is pretty much SOL getting it replaced.
    Displays are expected to last the life of the phone. Our definition of lifetime and a service providers vary greatly. Our version of lifetime is you get a new phone when you WANT to; lifetime to a Service Provider is the length of your contract.
    I love this phone, but if you can't see it, it's nothing more than a paperweight.
    Ok, I'll stop. If anyone has any suggestions as to how to repair this issue, I'd sure appreciate it.
    Gynotai
    Points: 8,456, Level: 62
    Level completed: 2%, Points required for next Level: 294
    Overall activity: 23.9%
    saul1991's Avatar
    37748
    1,317
    22 times
    Maybe try replacing the screen with a new one?
    Gynotai's Avatar
    39624
    San Jose, CA
    11
    Quote Originally Posted by saul1991 View Post
    Hi.
    Thank you for replying. Will replacing the screen solve the problem? Like 20 minutes after I posted the original message (of this thread) the display was almost solid. I'm an Electronics Technician by trade, and this doesn't make sense, the display coming and going like this. I'm thinking if the problem was the screen, wouldn't it always be the same?
    Another weird thing is when I run my finger from the top to the bottom of the screen and the Notifications screen comes on, all the notifications listed are rock solid; no flicker whatsoever.
    When Icons are on the screen, they don't flicker; only the background does.
    This leads me to believe it might not be the screen, but perhaps the electronics that drive it.
    I have a Stock Ticker on my phone that scrolls across the screen, and I thought it might be that, so I completely removed it from my phone and did a battery pull with no change.
    Is there anyone here that has fixed this problem not by replacing the phone?
    Thanks!
    Gyn
    Gynotai's Avatar
    39624
    San Jose, CA
    11
    Quote Originally Posted by Gynotai View Post
    Hi.
    Thanks!
    Gyn
    Hi.
    Did I stump the panel? If the only solution is to replace the screen or phone, I'm afraid I'll opt for the phone. With an (dare I say) iPhone.
    When it comes to my money, I only give companies one chance. When a product fails prematurely, and the only answer to fix it is to buy another one, I do; just not theirs.
    Gyn
    Points: 39,987, Level: 100
    Overall activity: 99.8%
    fezrock's Avatar
    29044
    Asheville-ish
    8,745
    217 times
    I'm leaning towards it being the digitizer. The screen sounds like it's fine.
    You can rule out a software bug with an sbf. Then reinstall apps individually to see if one of them is the culprit. The sbf will give you a factory-fresh system. It's maybe a bit extreme, but in the end may save you time by not having to try this or that quick possible fix. If the problem persists on a clean system it's in the hardware. There are quite a few videos and tutorials on digitizer replacement by now.
    Sent from my Galaxy Nexus using Xparent Blue Tapatalk 2
    Points: 1,553, Level: 22
    Level completed: 53%, Points required for next Level: 47
    nate7799's Avatar
    25525
    everett,wa usa
    23
    my phone started doing this as well.... goes away when i leave it plugged in for awhile...bought a new phone already..
    Points: 16,084, Level: 81
    Level completed: 47%, Points required for next Level: 266
    Overall activity: 57.7%
    maybish's Avatar
    20852
    new jersey
    5,411
    123 times
    Sorry for your screen problems!! Did you get a new x or a new phone?
    ****May's Galaxy****
    nate7799's Avatar
    25525
    everett,wa usa
    23
    I got LG Lucid for cheap... No roms, lame lg UI, but the 4G is nice. It'll do til a better option becomes available
    Points: 221, Level: 4
    Level completed: 43%, Points required for next Level: 29
    3 months registered100 Experience Points31 days registered7 days registered
    planejumper73's Avatar
    62299
    Oct 2012
    Does anyone know what the correct Torx tools are for this replacement? I've seen 2 different sets on eBay, with the screen. One comes with T-3 and T-4 tools. The other comes with T-5 and T-6 tools.
  1. screen flicker
    By sixfootfive in forum Droid X General Discussion
    Last Post: 12-01-2011, 06:48 AM
  2. Screen Issue (Line across top, slight flicker)
    By yambag021 in forum Droid X Help
    Last Post: 10-12-2011, 12:14 AM
  3. Partial screen flicker/static.
    By ejgilkey in forum Droid X General Discussion
    Last Post: 09-05-2011, 11:13 AM
  4. Severe Screen Flicker
    By FA1SGL in forum Droid X Help
    Last Post: 02-08-2011, 03:23 AM
  5. Droid X New Screen Issue
    By rocksolidsr in forum Droid X General Discussion
    Last Post: 08-17-2010, 07:29 PM
droid screen flickering
droid x bottom of screen flickering
droid x flickering screen
droid x flickering screen fix
droid x screen flashing
droid x screen flicker
droid x screen flicker fix
droid x screen flicker problem
droid x screen flickering
why is my droid x screen flickering
