Yes, I got the same error and yes from that link
This is a discussion on Bricked DX - Stuck at loader within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Yes, I got the same error and yes from that link...
Are you using your stock data cable or an after market or different phone cable? That can cause issues also.
Sent from my Liquid X
yes still using original data cable.
At this point you may need to download RSD Lite and SBF the stock .621 image to get the phone working and start over from there. I'll find a link to the image.
Here you go. Image and instructions included.
http://rootzwiki.com/topic/17934-602-sbf/
After the SBF the phone will probably be stuck in a boot loop. You'll have to do a data wipe in stock recovery and then it will boot.
EDIT: Here's another link to get the .621 SBF.
http://rootzwiki.com/index.php?/topi...-SBF#entry4280
