Please help me with this error code....
This is a discussion on Please help me with this error code.... within the Droid X Rescue Squad forums, part of the Droid X Discussion category; My phone accepted an update that I didn't authorize.... now this is the error my phone has and I can't figure out how to fix ...
Thread: Please help me with this error code....
    My phone accepted an update that I didn't authorize.... now this is the error my phone has and I can't figure out how to fix it....
    this is what the screen says:
    Bootloader
    30.04
    Err: A5, 70, 00, 00, 23
    Battery OK
    OK to program
    Transfer Mode:
    USB
    Points: 9,510, Level: 65
    Level completed: 54%, Points required for next Level: 140
    Overall activity: 99.7%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,209
    128 times
    That is your bootloader screen and also is what you would use to sbf your phone, which you may need to do, it appears that the update was incomplete or corrupted. You may wanna try a factory reset and see if you can get past this error.
    Step 1. Make sure your device is fully powered down/off Step 2. Press and hold the Volume Down, as well as the Home Button on your device Step 3. While keeping those 2 buttons pressed down, also press on the Power button Step 4. Once you see your screen flicker/flash (note: You might have to press a key on your device to see that you are actually booted into the Stock Recovery). Step 5. Once completed you should see a triangle, hit both volume buttons and then select factory reset.
    If this doesn't work, then I would say you need to sbf to fix it.
    teleported from MI Wizardry UI DXtreme
    Points: 7,324, Level: 56
    Level completed: 87%, Points required for next Level: 26
    Overall activity: 24.2%
    1,341
    78 times
    You need to SBF. This is a known issue with the .621 update and the Droid X, some phones take it, some don't. But rather than refusing the update it just gives bootloader errors.
    The .602 or .605 SBF is what you are looking for. Go to the link below, it will give you the files needed (you will need RSD Lite, a PC program, an SBF file, and your OEM charging cable). After SBFing I would highly recommend rooting so you could block that update going forward and avoid the issue possibly re-occuring.
    Here is the guide/link for the downloads:
    [Guide] Flashing Droid X SBF - Droid X - RootzWiki
    If you get issues with RSD Lite (happens sometimes) there is another way to flash it. Use the method here (using same version .602/.605):
    Points: 70, Level: 1
    Level completed: 40%, Points required for next Level: 30
    Overall activity: 2.2%
    solfour's Avatar
    59581
    Jun 2012
    6
    I had the the same exact problem a couple months ago before I forced myself to learn about sbf'ing, rooting, and flashing ROMs. At that point (in my noobish mindset ) my solution was to call up Verizon and whine to the service Rep to get me a new phone... Now that I know all that good stuff I feel so silly because I could've solved that problem on my own
  1. error with hotmail "authentication error receiving"
    By hunterchick in forum Droid X Rescue Squad
    Last Post: 04-09-2011, 01:45 AM
  2. Hmm. Network error or rom flashing error?
    By jesscepticon in forum Droid X ROMs
    Last Post: 03-25-2011, 11:17 AM
  3. USB error code
    By Bthuring in forum Droid X Help
    Last Post: 02-07-2011, 06:32 PM
  4. Replies: 7
    Last Post: 10-12-2010, 11:09 AM
error 602 galaxy s3
error 602 on galaxy s3
error 602 sprint
error code 602 sprint
error code 602 sprint galaxy s3
galaxy s3 error code 602
samsung galaxy s3 error 602
samsung galaxy s3 error code 602
sprint error 602
sprint error code 602
