Droid X Blank Screen Lights Alarming
This is a discussion on Droid X Blank Screen Lights Alarming within the Droid X Rescue Squad forums, part of the Droid X Discussion category; My droidX battery died a few weeks ago and the screen has not turned on since. There is a flashing blue light at times and ...
Results 1 to 9 of 9
Thread: Droid X Blank Screen Lights Alarming
    Points: 117, Level: 2
    Level completed: 34%, Points required for next Level: 33
    Overall activity: 1.8%
    rjblaze's Avatar
    59096
    Jun 2012
    7
    My droidX battery died a few weeks ago and the screen has not turned on since. There is a flashing blue light at times and a red light when plugged in, the hard keys also light up and twice now the phone has alarmed. The screen still does not come on. I am not sure what the issue is I bought an external battery charger to charge up my batteries hopefully that works, but it has not arrived yet. I figure the batteries are charged since it lights up and alarms which is weird.
    Please help me I am desperate
    Points: 3,956, Level: 40
    Level completed: 3%, Points required for next Level: 194
    Overall activity: 3.6%
    milski65's Avatar
    37085
    Orange, Va
    1,010
    15 times
    Quote Originally Posted by rjblaze View Post
    Just leave it plugged in for 30 minutes to an hour. Then long press and release the power button. It should come on. If not, try a battery pull.
    Sent from my DROID BIONIC using Tapatalk 2
    rjblaze's Avatar
    59096
    Jun 2012
    7
    Quote Originally Posted by milski65 View Post
    I've tried many battery pulls. I have also let it charge for hours then long press and release the power button and it still refuses to turn on. ill see the keys light up after a while and a blue light flashing but the screen is completely blank.
    rjblaze's Avatar
    59096
    Jun 2012
    7
    My external charger came. I charged up two of my batteries and nothing shows up on the screen. I might just have to kiss this phone goodbye.
    rjblaze's Avatar
    59096
    Jun 2012
    7
    Here is a look at the what the phone does
    Points: 7,188, Level: 56
    Overall activity: 29.0%
    1,340
    78 times
    Can you get into the bootloader (Battery pull, then press and hold Volume down and camera then press and hold power while still holding the other two)?
    If you can get into the bootloader its a software issue and either an SBF or factory reset will probably fix it.
    If you still get a black screen at that point you LCD has probably died. You can replace those if you do want to keep your phone, bit obviously its a bit technical.
    Sent from my Liquid ICS
    rjblaze's Avatar
    59096
    Jun 2012
    7
    I tried that, after a while i feel a vibration and nothing happens to the screen, it is still blank. I guess it is the LCD that is the problem.
    rjblaze's Avatar
    59096
    Jun 2012
    7
    any help out there? None of the boot instruction help. I cannot see anything on the screen. Maybe a wire went loose somewhere
    1,340
    78 times
    Yeah I'd say it sounds like next step is screen dissasembly. I haven't done it myself but there is tons of guides, I believe some here and you can google and find them easily. The only other thing I'd say to ensure its the screen is do the bootloader like listed above and then plug it in USB to the PC in RSD Lite and see if it recognizes it. If it does then its in the bootloader the screen just isn't showing it. You could SBF it at this point to make sure there was nothing in the firmware screwing it up, then do a blind factory reset/data wipe (I can give you the controls needed for that as its hard-key presses) but it sounds an awful lot like a busted screen or something hardware related.
  1. Rooted Droid X hangs on blank screen using Droid X Bootstrap
    By netized in forum Droid X Rescue Squad
    Last Post: 02-07-2012, 03:56 PM
  2. Blank Screen
    By Chrissyw in forum Droid X Hacks
    Last Post: 11-24-2011, 11:56 PM
  3. Droid X Turns On to Blank Screen
    By iarethom in forum Droid X Help
    Last Post: 08-28-2011, 04:07 PM
  4. Screen randomly lights up and then turns off again
    By hollywood in forum Droid X Help
    Last Post: 08-11-2011, 08:16 AM
  5. Blank the screen
    By johnfarrow in forum Droid X General Discussion
    Last Post: 11-19-2010, 10:30 AM
Droid x screen black
droid x black screen
droid x black screen fix
droid x blank screen
droid x lights
droid x screen blank
how to fix droid x black screen
motorola droid x black screen
motorola droid x blank screen
my droid x has a black screen
