[h=1]Stuck in bootloop Droid x in upgrade to CM9 beta[/h]I am stuck at the Motorola sign.
I accidentally didn't wipe data/cache before installing CM9 beta from CM7 nightly.
Please help. I think I might need to do a reset... but I can't do the power+volume down. Nothing comes up
Then I accidentally upgraded to .621! Stuck again. Tried sbfing again like previously, but it didn't work. I had to download and flash the .621 .sbf file. Then from there I rooted the .621 (using the linux method) into milestone .604. And now I am waiting till the CM9 stable version comes out. I only likely ICS based ones and I LOVED CM7, but I want working camera and wifi and everything. I heard there are some that have those fixes. Not sure. It's been quite a mess with my phone lately, and I'm just taking some time off before I get into another mess again!
