I took my DroidX apart for a new screen and this part fell out and I don't know where it goes? I assembled the phone without it and every thing works fine, but it bugs me having spare parts left over. Any ideas? Thanks.
This is a discussion on Does anyone know what this part is from my Droid X? within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I took my DroidX apart for a new screen and this part fell out and I don't know where it goes? I assembled the phone ...
Have you tried YouTube? There's a lot of videos of people taking apart there dx you might find some help on the video
Looks like a shim of some sort but I couldn't tell you where it goes. good luck.
Check out my themes:
Are you talking about the black thing or the clear thing?
It's the thing under the dime. It is steel or tin, not clear (bad pic). I am starting to think it might be one of the clips that holds the phone together near the volume buttons. I am noticing a little gap there after snapping the housing back together. I had not taken the phone apart before.
Take off your battery cover. Directly underneath the battery there are two plastic 'tabs' where there is a metal piece similar to what I THINK I'm seeing in the pic. If there is no metal piece there on your phone I'm pretty sure that's it.
Via Tapatalk
I looked in the battery comp. and I still have that piece. This part is a lot smaller, about 1/3 that size. If you zoom in, there are 4 little tabs on it. Thanks though.
it's a dime
Knight AdamTomaino of The X Clan!
