Flashed a Gingerbread ROM on a FROYO droid X. Battery Low, and Cant SBF. Wont boot up
This is a discussion on Flashed a Gingerbread ROM on a FROYO droid X. Battery Low, and Cant SBF. Wont boot up within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I SBF'ed my droid x back to Froyo. Forgetting my Sense rom is Gingerbread based, (with gb kernel and all that shabazz) it will not ...
Results 1 to 9 of 9
Thread: Flashed a Gingerbread ROM on a FROYO droid X. Battery Low, and Cant SBF. Wont boot up
    Points: 2,144, Level: 27
    Level completed: 96%, Points required for next Level: 6
    Overall activity: 7.4%
    Enyo's Avatar
    44053
    Jul 2011
    215
    Forgetting my Sense rom is Gingerbread based, (with gb kernel and all that shabazz) it will not boot. Battery Low and cant sbf either. Going into bootloader says Battery Low Cant program
    I Left the charger in and on the motorola screen, now the screen is off and the LED is Green.
    Anyone know what to do?
    If its just sitting at the motorola screen, does keeping the charger in charge the battery?
    I Still have that battery i messed up And can charge that one via cutting the usb cord.
    Points: 22,766, Level: 93
    Level completed: 42%, Points required for next Level: 584
    Overall activity: 36.7%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,666
    134 times
    I don't recommend cutting the cable... As it can take out the battery and the phone... But in bootloader mode it won't charge... So either if you have a friend with an x or x2... see if you can swap out batteries... Or if your local Verizon store will charge it for you
    "I'll get you my little pretty... and your little dog todo too"
    "I don't even have a little dog todo"
    Post Script:
    Nemo Aeternamn Wallpapers
    Enyo's Avatar
    44053
    Jul 2011
    215
    Quote Originally Posted by Nemo aeternamn View Post
    Its off, when I plug it in, The LED Turns green. The screen doesn't turn on.
    37333
    Mo-ab
    7,666
    134 times
    Quote Originally Posted by Enyo View Post
    Hmm... I'm not sure... try leaving it like that for like half an hour to an hour... And see if you can and from there
    Post Script:
    Rescue Squad
    Points: 27,141, Level: 97
    Level completed: 80%, Points required for next Level: 209
    Overall activity: 6.2%
    Leach19m's Avatar
    31277
    Washington
    7,062
    234 times
    It may be charging, but I wouldn't count on it. Like Nemo said, the best thing to do is to find someone with an X or X2 who's battery you can borrow, or pick up an external battery charger so you can charge your battery independent of your phone.
    Enyo's Avatar
    44053
    Jul 2011
    215
    Ok thanks
    I do still have that battery I messed up trying the Cut cord method. I might try that. Its a broken battery anyway.
    Enyo's Avatar
    44053
    Jul 2011
    215
    Left it in for a few. Once unplugged, LED takes a sec to turn off.
    A Few minutes ago, once I unplugged it turned off with no delay.
    Enyo's Avatar
    44053
    Jul 2011
    215
    Looked at my phone with shock that it was on the motorola boot logo.
    Took out the battery and reinserted it again plugging the usb cable in and, screen off with led light on.
    Enyo's Avatar
    44053
    Jul 2011
    215
    Now its in the screen that Displays a Battery with A Question mark in the middle. Does it charge in this mode?
    The battery wasn't damaged at all and was just working less then a hour ago.
    I got into recovery mode. stock recovery.
  1. Replies: 0
    Last Post: 02-10-2012, 01:38 AM
  2. **HELP** stock droid x wont boot (2 phones so far)
    By mikerowave in forum Droid X Stock Issues
    Last Post: 09-14-2011, 12:24 PM
  3. Droid x wont boot.
    By alexkingston in forum Droid X Help
    Last Post: 07-29-2011, 09:22 AM
  4. droid x wont boot up
    By rudolfthered in forum Droid X Rescue Squad
    Last Post: 02-13-2011, 01:41 PM
  5. HELP!!! Droid x wont boot after moto logo
    By mikejones396 in forum Droid X Help
    Last Post: 11-05-2010, 12:08 AM
android stock on boot for froyo
can you flash a gb rom on froyo with droid x
droid x boot screen battery low
droid x flash rom will not charge battery
droid x froyo rom
droid x stock gingerbread rom
droid x wont boot after rom
flashing droid x charges now but wont boot
my droid x with gingerbread won't turn on
sbf droid x froyo to gingerbread
