Droid X - Bootloader 30.04 - err:a5,70,70,00,1f
This is a discussion on Droid X - Bootloader 30.04 - err:a5,70,70,00,1f within the Droid X Rescue Squad forums, part of the Droid X Discussion category; What version did you have before you tried to flash the sbf...
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
Thread: Droid X - Bootloader 30.04 - err:a5,70,70,00,1f
  1. #31
    Points: 224, Level: 4
    Level completed: 48%, Points required for next Level: 26
    Overall activity: 5.5%
    31 days registered7 days registered100 Experience Points
    alfonso718's Avatar
    57324
    31
  3. #32
    Points: 1,171, Level: 18
    Level completed: 72%, Points required for next Level: 29
    Overall activity: 3.3%
    bobd27's Avatar
    33997
    Lakeland, FL
    74
    Quote Originally Posted by alfonso718 View Post
    ok thanks alot i was able to get my phone back to .621 now if i wanted to root it , if possible id have to go to .604?
    Yes, right now if you want to get root, you need to go to .604, it's real easy just go here and read and follow the instructions, it's done using linux but it is simple good luck
  4. #33
    Hello, I Also I have the problem with the bootloader I get:
    Bootloader
    30.04
    Err:A5,70,70,00,1F
    MEM_MAP Blank
    Service Reg'd
    Battery OK
    Ok to Program
    Transfer Mode:
    USB
    The initial problem was to try to change the rom, but when you restart the phone was left in the M logo, I read that if the SBF flasheaba again resolved the problem, but now I have this error, and use the methods mentioned here and that none has worked.
    I'm from Mexico
  5. #34
    Points: 623, Level: 12
    Level completed: 46%, Points required for next Level: 27
    iaminflames's Avatar
    58020
    7
    Please speak English?
  6. #35
    corrected, sorry for my bad English!
  7. #36
    Quote Originally Posted by iaminflames View Post
    Bootloader
    30.04
    Err:A5,70,70,00,1F
    MEM_MAP Blank
    Service Reg'd
    Battery OK
    Ok to Program
    Transfer Mode:
    USB
    I'm from Mexico
  8. #37
    Points: 35,547, Level: 100
    Overall activity: 42.3%
    1KDS's Avatar
    3981
    6,904
    572 times
    Looks like you used the wrong SBF file, who is your carrier?
  9. #38
    Hello, I want to comment out the error and achieve the bootloader, which I did was flash the SBF from here: [SBF and Update] Original Gingergread 2.3.4 SBF for Droid X MB810 Verizon USA - xda-developers
    But even if the phone does not pass the M logo, try to enter recovery mode but I can to make the combination of keys are left in the triangle with the android, I do not see the recovery menu, it could put the recovery through ADB or something similar.
  10. #39
    1KDS's Avatar
    3981
    6,904
    572 times
    At the droid/triangle screen press both volume buttons at the same time.
  1. droid x BOOTLOADER ???? (CM7)??
    By st3v3n in forum Droid X Hacks
    Last Post: 06-08-2011, 10:30 AM
  2. Droid X stuck at bootloader
    By caleb in forum Droid X Rescue Squad
    Last Post: 04-13-2011, 09:48 AM
  3. Droid X Bootloader
    By psychotic_penguin in forum Droid X News
    Last Post: 04-03-2011, 04:54 PM
  4. droid x BOOTLOADER ???? (CM7)??
    By st3v3n in forum Droid X General Discussion
    Last Post: 03-23-2011, 05:17 AM
  5. Droid X bootloader
    By wicked in forum Droid X General Discussion
    Last Post: 02-04-2011, 11:23 AM
bootloader 30.04
bootloader 30.04 Err:a5,70,70,00,1f
bootloader 30.04 err a5 70
droid bootloader 30.04
droid x bootloader 30.04
droid x bootloader 30.04 err
droid x bootloader 30.04 err a5
droid x err a5 70
droid x error a5
droid x2 bootloader 30.04
