changing settings/wallpaper for 3 different home screen settings
This is a discussion on changing settings/wallpaper for 3 different home screen settings within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Does anyone know how to find the settings for the homescrn? I found it by accident last night but cant get back to it. It ...
Results 1 to 6 of 6
Thread: changing settings/wallpaper for 3 different home screen settings
    Points: 132, Level: 2
    Level completed: 64%, Points required for next Level: 18
    ldywranglr's Avatar
    46997
    Aug 2011
    Does anyone know how to find the settings for the homescrn? I found it by accident last night but cant get back to it. It was home , office or work and play or something like that. You could change the wallpaper for each. when you set it, it changed back and forth by pressing the menu button and picking each folder. Anyone know how I can find this again?? Thanks
    Points: 6,119, Level: 50
    Level completed: 85%, Points required for next Level: 31
    Overall activity: 2.7%
    fc127's Avatar
    27223
    Cortland, NY
    1,173
    36 times
    You have to be using the stock launcher and you should be able to press the menu key and tap settings. This is only available on the STOCK LAUNCHER though.
    Root .602 & .605 info here.
    Need to SBF? Try this.
    ldywranglr's Avatar
    46997
    Aug 2011
    ya its stock. but when I go to settings/ display/ wallpaper, it just lets me change the original wallpaper. I found this other by accident and you could change it for three differnt. have any ideasa? thx
    fc127's Avatar
    27223
    Cortland, NY
    1,173
    36 times
    Oh, ok, I see what you are saying... I'm not sure where that feature is. Hopefully someone comes along that is running stock GB.
    Sorry i couldn't help you better...
    ldywranglr's Avatar
    46997
    Aug 2011
    thanks for trying
    Points: 2,707, Level: 31
    Level completed: 72%, Points required for next Level: 43
    holly's Avatar
    19007
    SF Bay area
    587
    13 times
    You mean menu key, then profiles? Profiles will get you to your various home screen profile options.
    To be honest I haven't used this function so there may be settings I'm not aware of.
    Sent from my non-rooted dx
  1. Sysctl settings keep changing to default
    By pharmnatr in forum Team Liberty
    Last Post: 08-21-2011, 05:02 PM
  2. Getting a black screen only on settings
    By Karrell5 in forum Droid X Help
    Last Post: 07-24-2011, 03:42 PM
  3. Replies: 0
    Last Post: 06-22-2011, 12:02 PM
  4. Changing home screen frame rate?
    By wcirco in forum Hacking Help
    Last Post: 01-07-2011, 09:28 PM
  5. changing settings screen
    By tttuning in forum Droid X FAQs
    Last Post: 09-21-2010, 10:06 PM
change profile droid x
droid 3 wallpaper settings
droid x screen profiles
droid x wallpaper settings
how to change home screen on droid x
how to change home settings on android
how to change profile on droid
how to change profiles on droid x
how to change wallpaper settings on droid 3
how to change wallpaper settings on droid x
