Help!!! Phone won't load from sd card or boot up!!!
This is a discussion on Help!!! Phone won't load from sd card or boot up!!! within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Hi all. I am pretty new to all this. I tried to load Apex 2.0 to my droid x and now it won't go past ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Help!!! Phone won't load from sd card or boot up!!!
    Points: 1,138, Level: 18
    Level completed: 38%, Points required for next Level: 62
    Overall activity: 1.0%
    bigpete0108's Avatar
    43542
    Jul 2011
    14
    Hi all. I am pretty new to all this. I tried to load Apex 2.0 to my droid x and now it won't go past the motorola boot when you first start up the phone. When I do a hard reset and wipe cache and factory reset then I try to load from my sd card but it keeps saying failed to open no such file exists and signatur verification failed. Also when I reboot it just freezes up. It is the 340 version and using froyo. Please help!!!
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,777
    125 times
    You can't load roms through stock recovery you have to load them through clockwork. I.e bootstrap into recovery then install from sd card
    Points: 17,050, Level: 83
    Level completed: 40%, Points required for next Level: 300
    Overall activity: 17.0%
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    Apex 2.0 can only be loaded from rooted .596 Gingerbread, so you'll need to flash the 2.3.340 sbf to fix. Keep your phone powered down until you're ready to flash the sbf so you don't drain the battery.
    Easiest method here...Easy SBF
    43542
    Jul 2011
    14
    I want to say on froyo though. I tried to load apex so now the phone is froze up. Is spf ing it the only way to fix it? Like I said I'm new to all this so I'm still trying to learn all the spf and flashing. I haven't dont any of that yet.
    43542
    Jul 2011
    14
    Sorry sbf.
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    You can try getting into clockworkmod recovery to restore a backup if you made one. Try these methods to get into clockwork...Boot Into Recovery From Power Off State
    But I'm pretty sure you'll need to sbf, so I'd go ahead and start downloading the 2.3.340 file from the link I provided. Just make sure to burn the disc as an image using the instructions in that thread...don't burn it just like a normal disc. We can help you through it, but that method should be easy going for you.
    cory46's Avatar
    8051
    4,777
    125 times
    Quote Originally Posted by bigpete0108 View Post
    Yes sbf is the only way to fix it. You'll be on froyo after the sbf is finished.
    Apex 2 is a gingerbread only rom which is why you got into problems
    Ninja'd
    43542
    Jul 2011
    14
    Thanks for the help. I am using a computer that doesn't have a cd burner at the moment so I will have to wait till tomorrow night. I will try it out then and if I have problems I will post again.
    cory46's Avatar
    8051
    4,777
    125 times
    If you have a USB drive you can use that
    43542
    Jul 2011
    14
    How? It acts like I can only burn to disc? Sorry I'm so not the smartest at computers.
  1. What is the correct way to load music onto SD card?
    By DrCarl in forum Droid X Audio / Video
    Last Post: 06-28-2011, 01:00 AM
  2. Boot loop after attempting to load materstcok update
    By gibsonmedic in forum Droid X Rooted Issues
    Last Post: 02-27-2011, 08:41 PM
  3. What is the correct way to load music onto SD card?
    By DrCarl in forum Droid X General Discussion
    Last Post: 02-08-2011, 05:13 AM
  4. Bricked phone, RSD Lite won't load SBF file
    By ejgilkey in forum Droid X Rescue Squad
    Last Post: 12-25-2010, 11:17 PM
  5. Replies: 9
    Last Post: 10-31-2010, 02:12 AM
boot droid x from sd card
droid 2 sd card stops phone from booting up
droid x freezes, won't load
droid x sd card wont load
droid x won't start up
how do you open up sd card on droid x
how to boot from sd card droid
how to load a sd card into droidx
how to load sd card into phone
phone wont load sd card
