Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked
This is a discussion on Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Hello, last night I put my phone on my charger, and when I woke up in the morning it was acting weird. Buttons weren't working ...
Results 1 to 10 of 17
Thread: Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked
    Hello, last night I put my phone on my charger, and when I woke up in the morning it was acting weird. Buttons weren't working right, Volume randomly went up/down, etc., etc. So I tried a battery pull to get it to work right again and I got the White triangle with the orange exclamation point and the droid guy thing. I heard to hit the search button, but nothing came up. I tried hitting power and home, but I just got the same message. I did the Camera+volume down+power combo and it went to the mode and said something like "Bootloader 30.04..... Battery OK.... OK to Program...." Connect USB Data Cable. I connected a USB to my computer and nothing happened. I have no clue what to do.
    I'm not rooted, and I don't have any custom ROM's. Haven't tinkered with anything like that.
    Please Help.
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    If you pull the battery and boot up without pressing any buttons, what happens?
    Is it stuck on the boot logo or animation?
    Sent from my X to the interwebz
    That logo again. No matter what I do that logo pops up.
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    If you are on the latest Gingerbread update, press both volume keys at the exclamation point. Then try a factory reset/data wipe...you use the power button to select.
    If that doesn't solve it, it almost sounds like a hardware issue with the hard keys.
    That worked. Do I want "Reboot system now" or factory reset?
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Quote Originally Posted by hockeydroid53 View Post
    Well, you can try reboot system now first and see if it boots up, and if not then try the factory reset.
    Alright, thank you. I'll post how it goes.
    Did factory reset, cleared cache, rebooted. Same ****ing icon.
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Did it not boot at all when you hit reboot system now?
    I think you need to either call Verizon or take it in to them, because it seems like it's a hardware issue. Since you haven't rooted or anything, a factory reset should have solved it if it was a software issue.
    The Motorola logo came up and then it just went back to the icon.
  1. Replies: 10
    Last Post: 09-27-2011, 08:26 AM
  2. Is there such a thing as a USB mic for the droid?
    By NY_ROCKER in forum Droid X Help
    Last Post: 07-01-2011, 12:13 PM
  3. Replies: 16
    Last Post: 06-27-2011, 02:51 PM
  4. Droid icon and exclamation triangle screen
    By Carpetman in forum Droid X Hacks
    Last Post: 06-25-2011, 10:48 AM
  5. Droid X Blue Triangle after SBF
    By Shamrock in forum Droid X Rooted Issues
    Last Post: 11-01-2010, 07:15 PM
android icon white triangle exclamation point
droid x exclamation point white triangle
droid x white triangle yellow exclamation point
droid yellow exclamation point
motorola droid triangle exclamation point
my android has an exclamation point
my droid has a triangle with an exclamation mark
orange triangle with white exclamation point
white triangle with exclamation point droid
white triangle yellow exclamation and a phone.
