Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked
This is a discussion on Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked within the Droid X Rescue Squad forums, part of the Droid X Discussion category; That's really strange...never heard of that. Yeah, I would take it back and get a replacement, unless you really want to try to flash the ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Help - Triangle, Exclamation Point, Droid guy thing on Boot. Nothing has worked
    Points: 17,073, Level: 83
    Level completed: 45%, Points required for next Level: 277
    Overall activity: 16.7%
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    That's really strange...never heard of that. Yeah, I would take it back and get a replacement, unless you really want to try to flash the Gingerbread sbf as a last resort...if so, we can help with it
    Sent from my X to the interwebz
    Does it involve opening the phone up?
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    No, it's safe to do, but you don't want you're battery to run out during it, or it won't charge the battery in the phone if it fails. So, if you want to try, power off your phone to save the battery until you're ready to flash it.
    You'll need a burnable CD or a thumb drive to burn the image to, and the file and instructions are here...SBF Live Disc (Note: you want the second download for 4.5.596 Gingerbread).
    Points: 3,387, Level: 36
    Level completed: 25%, Points required for next Level: 113
    Overall activity: 5.6%
    Snipples007's Avatar
    34930
    New York
    814
    11 times
    I just want to say that I have done well over 20 SBFs to this phone. There is absolutely nothing to worry about. It is really nerve racking the first couple times, but I assure you that your phone will be fine.
    Running GingerSnips v. 007
    I think I'll just take it to Verizon... seems too complicated for me. Thanks for you help though.
    I have had the same problem but, I have service through page plus. Is there a way I can fix the hardware issue myself?
  8. #17
    Points: 39,188, Level: 100
    Overall activity: 99.7%
    fezrock's Avatar
    29044
    Asheville-ish
    8,586
    216 times
    Quote Originally Posted by maverickzz123 View Post
    Can you explain your problem in more detail? Events leading up to, etc, etc?
  1. Replies: 10
    Last Post: 09-27-2011, 07:26 AM
  2. Is there such a thing as a USB mic for the droid?
    By NY_ROCKER in forum Droid X Help
    Last Post: 07-01-2011, 11:13 AM
  3. Replies: 16
    Last Post: 06-27-2011, 01:51 PM
  4. Droid icon and exclamation triangle screen
    By Carpetman in forum Droid X Hacks
    Last Post: 06-25-2011, 09:48 AM
  5. Droid X Blue Triangle after SBF
    By Shamrock in forum Droid X Rooted Issues
    Last Post: 11-01-2010, 06:15 PM
android exclamation mark triangle
android symbol with exclamation mark
android white triangle exclamation point
droid triangle with exclamation mark
droid x exclamation point white triangle
droid x triangle with exclamation point
droid x white triangle yellow exclamation point
my droid x has an exclamation point
white triangle orange exclamation android
white triangle with exclamation point android
