How to charge a bricked phone?
This is a discussion on How to charge a bricked phone? within the Droid X Rescue Squad forums, part of the Droid X Discussion category; So I know I need to flash back using an SBF, only problem being I don't have enough battery to do so... does anyone have ...
Like Tree4Likes
  • 1 Post By sk1ttl3s
  • 1 Post By DMXL
  • 1 Post By Rorence
Thread: How to charge a bricked phone?
    sk1ttl3s's Avatar
    8136
    Billings, MT
    14
    So I know I need to flash back using an SBF, only problem being I don't have enough battery to do so... does anyone have any ways to charge it while it's bricked?
    smartessay likes this.
    Points: 617, Level: 12
    Level completed: 34%, Points required for next Level: 33
    DMXL's Avatar
    36457
    108
    I believe tbh sells a special usb cable that will charge a bricked x... Do not try to charge regularly, it will cause your phone to over heat
    And get damaged
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    If it's stuck in the bootloader, it won't charge. Your best option is to borrow a battery from someone who has a DX, or get them to charge your battery. Otherwise, you could buy a battery from Verizon, which should have enough charge...or some have reported that Verizon will charge the battery for you. Once you get a well charged battery, keep the phone off until you're ready to flash the sbf.
    The TBH cable mentioned or an external battery charger would work too, but you'd have to order those and they would take a few days. Those are good options to think about for the future, so you won't have to worry about this issue...
    sk1ttl3s's Avatar
    8136
    Billings, MT
    14
    Thank you both for your response! It was actually a D2G but I figured I trust my fellow DX'ers better :P I was able to find someone in town with a D2 and flashed back with an SBF... all in all I got it unbricked but never playing with that again :P I hate D2's!
    Points: 150, Level: 2
    Rorence's Avatar
    90580
    May 2017
    6
    Hello, guys. Sorry to say that I don't know how to fix that case. The way for me to charge phone in car is to use 300w power inverter. Simply to connect this charger with car cigarette lighter charger outlet. Then we can use it to charger phone, shaver, laptop or other tools safely. If you want to catch more details about this charger, you can search bestekmall on Google. Wish this tip is helpful to you. Best regards.
  1. Will phone charge if I am only seeing the M Logo??
    By Droidinite in forum Droid X Hacks
    Last Post: 09-14-2010, 11:57 AM
  2. A Car Mount that actually charge your phone too??
    By Kmasum in forum Droid X Accessories
    Last Post: 09-10-2010, 10:20 AM
  3. Turned on phone-down 10% since charge
    By AsterDroid in forum Droid X Help
    Last Post: 08-09-2010, 10:42 AM
  4. No charge, no phone
    By Tehtsuo in forum Droid X Help
    Last Post: 08-04-2010, 05:51 AM
  5. Time it takes to charge phone
    By mp7123 in forum Droid X Help
    Last Post: 07-29-2010, 12:02 PM
charge bricked phone
charging a bricked phone
charging bricked phone
how do you charge a bricked phone
how to charge a bricked phone
how to charge a droid x battery without the phone
how to charge battery on bricked phone
how to charge bricked droid x
how to charge bricked phone
how to charge droid x brick
