Stuck in Bootloop - Recovery Mode not working
This is a discussion on Stuck in Bootloop - Recovery Mode not working within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I'm running the non rooted 4.5.588 leaked Gingerbread. I wanted to update to 4.5.595 to get the official GB. I downloaded Gingerbreak and D2 Boostrap ...
Results 1 to 7 of 7
Thread: Stuck in Bootloop - Recovery Mode not working
    100 Experience Points7 days registered
    lukane77's Avatar
    36794
    7
    I'm running the non rooted 4.5.588 leaked Gingerbread. I wanted to update to 4.5.595 to get the official GB. I downloaded Gingerbreak and D2 Boostrap Recovery. Rooted the phone, and booted into clockwork recovery mode. When I ran the 595-stock.zip file I received and error, so i hit reboot.
    Now I'm stuck at the red circle M. When I boot into recovery, I hit the search button and nothing happens.
    Not sure where to go from here. Did I brick the phone?
    Thank you for any help you can give.
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    I believe when in stock recovery you use the volume keys instead of the search key.
    Points: 10,712, Level: 68
    Level completed: 66%, Points required for next Level: 138
    Dustin0308's Avatar
    24203
    1,490
    37 times
    Yes the search key is for froyo. When you get the little green android with the exclamation point, you hit the search key. On gingerbread when you get that, you hit both volume keys (the little indent in the middle of both volume keys is what you hit). This will take you into stock recovery. It should be pretty much self explanatory from there. Try doing a factory reset on stock recovery. Of that doesn't help try getting into custom recovery (D2 bootstrap). Restore your last GINGERBREAD (not froyo) backup. If that doesn't work, sbf.
    Heres how to get into custom recovery from power off state:
    Boot Into Recovery From Power Off State
    If u can't get into custom recovery and the factory reset in stock recovery didn't work. You will need to sbf. Heres how:
    http://www.droidxforums.com/forum/dr...-problems.html
    LiBeRtY TWOpointZEROpointONE
    RS Team Leader
    Points: 25,439, Level: 96
    Level completed: 9%, Points required for next Level: 911
    Overall activity: 15.1%
    popcenator's Avatar
    21238
    Omaha, NE
    8,255
    177 times
    I believe you are suppose to rename the .595 zip to update.zip and it should be the only one on the SD card.
    GBLDX
    lukane77's Avatar
    36794
    7
    And my phone is back! I was able to use the linux flash back to froyo. Thank you so much!
    RS Team Leader
    popcenator's Avatar
    21238
    Omaha, NE
    8,255
    177 times
    Glad you're back!
    GBLDX
    Dustin0308's Avatar
    24203
    1,490
    37 times
    Quote Originally Posted by lukane77 View Post
    Great news
  1. Replies: 0
    Last Post: 04-25-2011, 01:48 PM
  2. stuck on bootloop
    By Wapile in forum Droid X Help
    Last Post: 04-23-2011, 06:56 PM
  3. Stuck in Bootloop
    By darkstar73 in forum Droid X Help
    Last Post: 02-13-2011, 06:25 PM
  4. Bootloop and cant get into recovery
    By HellHound in forum Droid X Rescue Squad
    Last Post: 01-03-2011, 02:59 PM
  5. Clarifications on Bootloop, Brick, and Recovery Menu, and ROM
    By davidx in forum Droid X General Discussion
    Last Post: 08-21-2010, 12:45 PM
android recovery mode not working
droid x gingerbread recovery mode
droid x recovery mode
droid x recovery mode gingerbread
droid x recovery mode not working
droid x stuck in recovery mode
recovery mode android not working
recovery mode droid x
recovery mode droid x not working
recovery mode not working android
