HELP: Installed FB workaround for GB Liberty on Liberty 2.0.1 and now in bootloop.
This is a discussion on HELP: Installed FB workaround for GB Liberty on Liberty 2.0.1 and now in bootloop. within the Droid X Rescue Squad forums, part of the Droid X Discussion category; So....I downloaded the Facebook workaround zip file found here: http://www.droidxforums.com/forum/gi...orkaround.html I then installed it by doing this: 1. Click Droid X Bootstrap app, hit bootstrap ...
Results 1 to 2 of 2
Thread: HELP: Installed FB workaround for GB Liberty on Liberty 2.0.1 and now in bootloop.
    Points: 2,044, Level: 27
    Level completed: 30%, Points required for next Level: 106
    quasarquinn's Avatar
    1531
    Wayne, PA
    12
    1. Click Droid X Bootstrap app, hit bootstrap recovery, click ok, then reboot recovery.
    2. Install zip from sd card
    3. Go to folder where zip is. If you downloaded zip from stock browser and didn't move it, it will be in the DOWNLOAD folder.
    4. Click on the zip you want to install, then yes.
    5. Once install is finished, back arrow, and reboot.
    Once I rebooted, the liberty logo appeared and stayed there.
    I figured I messed something up so I tried to go back to bootstrap recovery by doing a battery pull but it just went back to the liberty logo again. I then tried to boot into stock recovery. I held down power and the hard home key until the green android guy and ! came up, then I clicked the hard search key, then wiped the cache, then wiped data/factory reset, then rebooted.
    Now it gets passed the Liberty logo but a yellow load bars shows up in the middle of the screen. It looks like it is moving but then it doesn't do anything. I waited a while, then tried rebooting from stock recovery. I done this about 6 times now and am still getting the yellow bar.
    How do I get back to clockwork recovery?
    Sorry for the long post but I figured I would explain exactly what I did so you wonderful people will have an easier time in assisting me.
    1531
    Wayne, PA
    12
    Nevermind...I fixed it. How do I delete this thread?
  1. liberty manual facebook workaround
    By zlittell in forum Team Liberty
    Last Post: 06-03-2011, 11:33 AM
  2. please tell me if i installed liberty correctly?
    By lucas in forum Hacking Help
    Last Post: 04-18-2011, 11:14 AM
  3. liberty 1.5 bootloop--first install
    By whataberger in forum Droid X Rooted Issues
    Last Post: 03-16-2011, 07:50 PM
  4. Installed Liberty 1.5 and can't change wallpaper
    By boston0108 in forum Hacking Help
    Last Post: 02-17-2011, 08:02 PM
  5. Installed Liberty 1.5 and can't change wallpaper
    By boston0108 in forum Droid X Help
    Last Post: 02-12-2011, 07:47 AM
can't update fb app on liberty
facebook for liberty 2.0.1
facebook link for liberty 2.0
facebook update liberty 2.0.1
how to dowlowd facebook 2.01
liberty 2.0 loop droid x
liberty 2.0.1 facebook
on liberty 2.0 now what
update facebook app on liberty 2.01
update facebook on liberty 2.0.1
