another flashed non root GB, then Flashed to 2.3.340... market problem
This is a discussion on another flashed non root GB, then Flashed to 2.3.340... market problem within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I flashed to non root GB from rooted Froyo, stock rom... then flashed to 2.3.340 and now i can't install any app from the market... ...
Thread: another flashed non root GB, then Flashed to 2.3.340... market problem
    Points: 717, Level: 14
    Dasfxt's Avatar
    18810
    I flashed to non root GB from rooted Froyo, stock rom... then flashed to 2.3.340 and now i can't install any app from the market... computer will not see the sd card usb mass storage either. i have tried wipe data and cache three times. i can't even install apk from the net. i went into recovery and tried the sd card update and it says E: failed to verify whole-life signature E: signature verification failed Installation aborted.
    I know i have a update.zip and the DXGBROOT.zip on the sd card... what am i doing wrong? Do i need another SBF file? thank you for all your great work.
    Points: 5,955, Level: 50
    Level completed: 3%, Points required for next Level: 195
    scottpole's Avatar
    27229
    1,119
    38 times
    Are you on the non rooted gingerbread?
    Wait I misread so your on froyo now?
    Warm Gingerbread with super user icing
    Points: 853, Level: 15
    Level completed: 53%, Points required for next Level: 47
    250 Experience Points31 days registeredTagger Second Class100 Experience Points7 days registered
    CAEM X's Avatar
    30225
    73
    Are u using RSD to flash the SBF ?
    Have tried this ?
    Complete Droid X .sbf Flashing Guide
    DX Rooted | Apex V2.0 RC2 | OC'd @ 1.3GHz
    Dasfxt's Avatar
    18810
    thank you for the reply... I am using RSD to flash the sbf files....i'm reading into the guide and downloading the maderstock file 2.3.340. i am on stock 2.3.340 now but the market does not install any app therefore i can't reload all my root apps like koush bootstrapper and titanium pro. i have tried installing a new market apk and that didn't install either. when i plug the phone into the computer via usb the sd card mass storage does not show up.
    Dasfxt's Avatar
    18810
    okay... i took out the micro sd card and the market works fine.... seems like the sd card is not allowing me to install any apps at all... i have z4root.apk on it but it won't install... do i need a new update.zip?
    Update: i deleted all update.zip and rom zip files and installed z4root and new clockwork and now i'm on GB root. YAY!.. didn't think a file on the micro sd can be corrupted.
  1. Updating a flashed Droid X?
    By russader in forum Droid X General Discussion
    Last Post: 01-13-2011, 08:54 PM
  2. Just flashed Android to an HTC HD2
    By Garemlin in forum Off-Topic Discussion
    Last Post: 01-09-2011, 06:46 PM
  3. Flashed the . 15 sbf, did I just lose all my contacts?
    By mpetruzz in forum Hacking Help
    Last Post: 12-22-2010, 02:23 PM
  4. flashed first rom darkslide 4
    By esquire in forum Droid X Rescue Squad
    Last Post: 12-16-2010, 09:08 PM
  5. Flashed SBF for 2.1 and got 3.0! Screenshot
    By DX-FTW in forum Droid X Hacks
    Last Post: 09-04-2010, 12:34 PM
cant flash 2.3.340 from rooted gb
droid x install failed 2.3
droid x rooted gb market not working
droid x superuser signature verification failed
i cant root my droid x gb
installing sbf 2.3.340 signature verification failed
maderstcok ota 2.3.340 signature verification failed
non market droid flash
signature verification failed droid x
usb mass storage droid x 2.3.340
