aol connection error?
This is a discussion on aol connection error? within the Droid X Rescue Squad forums, part of the Droid X Discussion category; I have been having an aol connection error. Running Rubix right now. Did the same on Fission. I have deleted the account and re-entered it ...
Results 1 to 6 of 6
Thread: aol connection error?
    twistedlim's Avatar
    31441
    I have been having an aol connection error. Running Rubix right now. Did the same on Fission. I have deleted the account and re-entered it and still it will not refresh fully without giving me the "connection error" at the top of the page.
    Any ideas?
    Thanks,
    Rich
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    AOL seems like a dead email service. Have you set it up manually?
    twistedlim's Avatar
    31441
    Yea I set it up like I have done on every phone and rom. It is not working for some reason now. I am thinking it had something to do with me flashing back and forth between Rubix and Fission. I downloaded (purchased) Enhanced Email and was able to get the email working like it was before. I am thinking of wiping everything and starting over.
    twistedlim's Avatar
    31441
    Yea its dead but I have used it for my business for years and can't really change it. Anyway, had the phone up and running various roms w/o issue and all the sudden it stopped syncing. May have had something to do with me flashing back and forth between Rubix and Fission. I am not confident all tracks are covered when you do that. Anyway I am purchased Enhanced email and it works (albiet a bit pricey) for now. I think I am going to go the madderstcok rout and start back fresh. I think the sync issue has to do with with Rubix. I had some minor sync issues with that rom so maybe something carried over.
    Thanks
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Just download and flash maderstcok update zip the same way you do ROMs and it will take you to a stock 2.3.340 setup.
    twistedlim's Avatar
    31441
    Thanks, will give it a try if I have to. After I deleted the regular email and installed Enhanced Email it was better. I wiped and reloaded fission and the stock email now seems to be working. I am thinking it was a bug in the stock email that kept being transfered over from one rom to another. We'll see how it goes over time.
  1. No connection?
    By t.crawford714 in forum Droid X Help
    Last Post: 03-22-2011, 06:03 AM
  2. Market connection error? Please try again?
    By macpro88 in forum Droid X Help
    Last Post: 03-16-2011, 02:16 PM
  3. Wi-Fi Connection WPA
    By droidxfan in forum Droid X Help
    Last Post: 09-17-2010, 09:02 AM
  4. gmail "no connection" error message
    By hiprider in forum Droid X Help
    Last Post: 09-14-2010, 04:01 PM
  5. Help with Mac Connection
    By egrafx in forum Droid X Help
    Last Post: 08-25-2010, 01:12 PM
android aol connection error
aol account error droid
aol connection error android
aol connection error droid
aol connection error droid x
aol connection error on android
connection error aol email android
droid x aol connection error
