Sd card issues
This is a discussion on Sd card issues within the Droid X Rescue Squad forums, part of the Droid X Discussion category; All of a sudden my sd card isn't working. It says that it's busy our unmounted, then when I check the alert in the status ...
Thread: Sd card issues
    Kristinkat's Avatar
    29021
    Sd card issues
    All of a sudden my sd card isn't working. It says that it's busy our unmounted, then when I check the alert in the status bar, it says its format is unsupported. So now all off my pictures and videos are lost. Is there anything I can do to fix this??
    Points: 3,046, Level: 33
    Level completed: 98%, Points required for next Level: 4
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    Try putting it in your computer and see if you can take the stuff from it. Then put.it in the phone.and.format it then put the stuff back on the card. (If you.can take it off in the first place). Good luck
    Points: 1,002, Level: 17
    Level completed: 2%, Points required for next Level: 98
    Overall activity: 0.0%
    FAMOUSX1's Avatar
    7375
    40
    Im having the same problem right now. All my music and pictures are gone and it wont let me mount the sd card.
    Anyone else having this issue ever on their dx?
    This is the 2nd time this has happened to me.
    Points: 728, Level: 14
    Level completed: 28%, Points required for next Level: 72
    athack's Avatar
    24584
    Buffalo NY
    15
    Quote Originally Posted by FAMOUSX1 View Post
    im on my third sd card this week... all programs on sd card work fine... seems that just music and pics are screwed up... they all show up and work fine on computer... tried to mount unmount sd card.. copied everything from sd to computer and back..new sd card put everything back from computer..frustrating
  1. Replies: 131
    Last Post: 02-18-2011, 04:01 AM
  2. Replies: 3
    Last Post: 12-25-2010, 12:17 PM
  3. sd card issues
    By RobertS in forum Droid X Help
    Last Post: 11-01-2010, 04:01 PM
  4. SD card/Droid X Media issues
    By e3zkiel in forum Droid X Help
    Last Post: 09-12-2010, 02:48 AM
  5. Replies: 2
    Last Post: 08-14-2010, 10:52 AM
SD card is busy droid x
droid razr say sd card unmounted
droid x sd card is unmounted or unavailable
my droid keeps saying sd card is unmounted when it isnt?
my sd card says its unmounted or is busy
sd card is busy
sd card is unmounted or busy
sd card unmounted or busy
sd card unmounted or busy?
unmounted or busy card
