Changing from swype text input to normal. How?! Help
This is a discussion on Changing from swype text input to normal. How?! Help within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Ok somehow my input method got switched to swype mode and I hate it. I go back to input Method and my normal option is ...
Results 1 to 7 of 7
Thread: Changing from swype text input to normal. How?! Help
    Method and my normal option is gone, all I have is swype. How do I get back to normal?!
    Thank you
    Points: 3,437, Level: 36
    Level completed: 58%, Points required for next Level: 63
    bigmook's Avatar
    14072
    southern idado
    374
    17 times
    Did you by chance. Delete the keyboard somehow. I use better keyboard it lets you set key height. So my big thumbs can still hit the spacebar .. try downloading that or the free version .. otherwise I would select remove default.
    For swype in the application settings
    sent from my private IDAHO
    Points: 42,333, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    Try a battery pull and look again before you do anything else.
    Points: 123,642, Level: 100
    Overall activity: 92.9%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    You could also try going into menu > settings> Language & Keyboard. See what is listed in there. It will give you a list of all keyboards installed. See if it is still there.
    Well I guess I did delete it somehow.. Idk how. But anyway I could get it back? If not, is the better keyboard recommended?
    bigmook's Avatar
    14072
    southern idado
    374
    17 times
    I really like just for the custom skins and the.aforementioned. key height adjustments
  1. Swype blocking text box
    By doug494 in forum Droid X Apps
    Last Post: 09-13-2010, 01:05 PM
  2. Text Messages Taking longer than normal to load
    By peterk814 in forum Droid X General Discussion
    Last Post: 08-10-2010, 03:51 PM
  3. Text input volume
    By eugdroidx in forum Droid X General Discussion
    Last Post: 07-24-2010, 01:13 PM
  4. Changing Text Size?
    By dan266 in forum Droid X Help
    Last Post: 07-20-2010, 12:51 AM
  5. DROID X - Text Entry, Swype, Speech to Text
    Last Post: 07-15-2010, 12:36 AM
change text mode android
how do i change my swype keyboard back to normal
how do i change my texting to swype
how to change my swype setting back to regular
how to change swype back to normal keyboard
how to change text input to swype
how to change the swype keyboard back to normal
how to get out of swype mode
how to i change my text to swype
how.do i,switch from swype to normal keyboard on ipad
