Boot Into Recovery From Power Off State
This is a discussion on Boot Into Recovery From Power Off State within the Droid X Rescue Squad forums, part of the Droid X Discussion category; EDIT: theres now 4 ways to do this. try all of them if you need to get into clockwork! ok. we all know how the ...
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 121
Like Tree20Likes
Thread: Boot Into Recovery From Power Off State
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    ok. we all know how the bootloader is locked and bootstrap is a hack to hijack the boot process. and i never read of a way to ACTUALLY boot into clockwork from a power off state. but then i was reading around on XDA and found something about this. started to mess with it and it worked for me and a few other staff members so lets see how this works for everyone else.
    i tried a few times to get it right. right now (gummy 2.5, bootstrapped, clockwork also flashed overtop) i can hold the power button and volume down button (both, not releasing the power button) and get into clockwork.
    NOTE: clockwork AND bootstrap are both flashed, not just bootstrap. after you flash the bootstrap, go into Rom Manager and choose flash clockwork recovery overtop (its the same menu, just a different way of booting)
    Main reason this is a big deal: you can now restore a backup (if it boots correctly) when on a bootloop if you can use this method to get into CW - as long as you dont mess up the files that make CW work (very scientific I know)
    -also, as a side note, it sometimes freezes on the M, but just do a battery pull and hold down the two buttons and try again.
    lets get some feedback!
    EDIT: from DF member Jolly, this works (for me and him) too.
    Also if you Battery Pull with your phone plugged up to the Charger and put the battery back in wait until it goes into the Charging State, the recharging Battery Icon. When you see that hit the power button and it will take you straight to Clockwork Recovery. Works Perfectly Everytime.
    EDIT2: X-Tac23 posted this method. worth trying if the other two dont work
    Quote Originally Posted by X-tac23 View Post
    So earlier my phone went into a boot loop, and i couldn't get into clockwork recovery, and I found a trick. It only seems to work when your stuck either at the M or in a bootloop.
    First hold the home and the power button till you get the triangle, and from there press the search the button to get into stock recovery. Then simply reboot. That SHOULD put you in clockwork recovery.
    I tried this multiple time and it worked every time. Not sure if anyone knows this trick so I tought I would make a thread.
    I am not responsible if this doesn't work for your phone. And this is not a way to Unbrick your phone!
    EDIT3: xrazedz suggested this and it seems to work too
    Quote Originally Posted by xrazedx View Post
    Hey abe, another method that i have used for months and always works is holding the power and camera button at the same time when powering on the phone and releasing the power button first. Then release the camera button a second or two later and it boots into clockwork recovery.
    I have used this method for months and it has worked every time across different roms.
    Swyped n sent from my X
    Points: 1,340, Level: 20
    Level completed: 40%, Points required for next Level: 60
    bratliff's Avatar
    22602
    Ky
    142
    That is awesome..so much better than sbf....feels more like og droid.
    Points: 46,436, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    Worked fine for me as well, this is awesome if this is what we think it is a possible way out of a boot loop without having to wipe.
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Quote Originally Posted by bratliff View Post
    i take it it worked for you?
    bratliff's Avatar
    22602
    Ky
    142
    Quote Originally Posted by Abe21599 View Post
    Well I was meaning the news..but I tried about 10 times..always just booted up..
    Gummy jar 2.5, bootstrapped, then clockwork..shut off..hit power and volume down until gummy jar came up...never got clock work recovery..any other buttons?
    Edit I tried releasing the power button same result.
    Do you have to reboot with boot strap once before?
    Edit..one last try..flashed bootstrap.flashed sp recovery then clockwork..shut down held power and vol down..still just booted up normal.any suggestions? I will look it up on xda tomorrow..its late here and my kids get up early..night all
    Points: 1,074, Level: 17
    Level completed: 74%, Points required for next Level: 26
    Overall activity: 0.0%
    dbscothorn's Avatar
    19141
    19
    This worked great! Thank you so much. I got stuck in a bootloop and don't know how to sbf from .340. This thread saved me. Held both buttons (without letting go of power) until clockwork came up and restored a back up. Thank you, thank you kind sir.
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Bratliff try a battery pull and not shutting down.
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Quote Originally Posted by dbscothorn View Post
    Glad to know it worked for someone!
    bratliff's Avatar
    22602
    Ky
    142
    Ok.flashed bootstrap..flashed clock work..pulled battery same result..normal boot cycle.
    I tried to find the xda thread but couldn't..
    I am also running the data throttle removed..doubt it matters..Phone needs to charge and so do I. I will follow up in a few hours...i really want this to work..
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    On my phone but tomorrow ill add the xda thread
  1. Can't boot into clockwork mod recovery
    By omnicious in forum Hacking Help
    Last Post: 12-25-2010, 02:44 PM
  2. CWM will not boot into recovery/backup
    By Eyefro69 in forum Droid X Hacks
    Last Post: 11-16-2010, 07:28 PM
  3. Replies: 3
    Last Post: 11-10-2010, 01:07 PM
  4. Replies: 5
    Last Post: 11-06-2010, 08:58 PM
  5. cant boot into recovery with rubix 1.0
    By wezley in forum Droid X ROMs
    Last Post: 10-23-2010, 09:31 PM
boot droid x into clockwork recovery
boot droid x into recovery
boot into clockwork recovery droid X
droid x boot into clockwork recovery
droid x boot into recovery
droid x how to boot into CLOCKWORK recovery
how to boot droid x into clockwork recovery
how to boot droid x into recovery
how to boot into clockwork recovery droid x
how to reboot droid x
