This is a discussion on Boot Into Recovery From Power Off State within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Originally Posted by roderick5881 when I rooted my X it never went into recovery. Its seems to be rooted, because su and bootstrap are working, ...
Alright...I may have missed something way back when I first flashed my D2 bootstrap while rooting my stock .605. All went well, rooted, and flashed CM74DX onto my phone. Since that time I've flashed several variants of Pooka's CM7 over on RootzWiki, but I never again re-flashed my D2 bootstrap since that very first time while rooting. After reading this thread, and not being able to get into CWM from power off using ANY of the suggested methods, nor with any of my own "proprietary" attempts, I'm really wondering if it isn't because I never re-flashed the D2 bootstrap. Honestly, until reading this thread, I thought it was a one-time before rooting thing, and never considered I'd have to do it again unless I SBF'd back to stock. So...have I read correctly in this thread that one MUST RE-FLASH the D2 bootstrap after flashing a new ROM?
FWIW, I have no bootstrap app, though I vaguely recall I once did (I recall rebooting into recovery once using it if I'm not mistaken).
Thanks.
DroidX, CM7.1, ADW Launcher EX
I so thought i was in trouble!!! I installed miui earlier and went to change the font like i usually do but my battery was probably at like 29%. For some reason it bootlooped and knew i couldnt sbf with a low battery!!! tried all the methods in the original post and none worked....saw this one then bam!!! Reflashed miui and now im back in business! thanks dd!!!
I'm actually not sure what boot menu us....but if it helped out im glad its there!!!
ok so i finally got my dx rooted and flashed a ics rom and the phone was faulty, so i got another and i flashed it and after the motorla "m" it just stays black and ive tried al the methods u said and no luck plz help this is my only phone
What system version were you on? .602, .605 or .621? When you went to flash the other ROM what did you use? CWM or bootstrapper?
Worse comes to worst an SBF would have returned your phone to 100% working order...
Sent from my XT926 using Xparent Cyan Tapatalk 2
