Boot Into Recovery From Power Off State
This is a discussion on Boot Into Recovery From Power Off State within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Originally Posted by jtp755 These are the only ways that work for me: Start from powered off state and then... Stock recovery - Hold power ...
Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 121
Like Tree20Likes
Thread: Boot Into Recovery From Power Off State
  1. #101
    Points: 2,696, Level: 31
    Level completed: 64%, Points required for next Level: 54
    Overall activity: 1.4%
    Scott26's Avatar
    26144
    163
    Quote Originally Posted by jtp755 View Post
    Stock recovery - Hold power button and home key. At the triangle with an exclamation point, press BOTH volume keys. Navigate with the volume buttons and select with the power button.
    CWMR - Hold power button and volume down. Release power button at M logo, continue to hold volume down until you are in CWMR. Navigate with the volume buttons and select with camera button.
    I am currently running stock from the 2 part flash of GB with D2 Bootstrap used to flash recovery.
    Thank you for the tip the Power + Volume technique worked perfectly!
  3. #102
    Scott26's Avatar
    26144
    163
    Quote Originally Posted by Scott26 View Post
    I am not sure if it has been mentioned here or not but after 45 min of trying everyone else method I did it a way I had used before that seems to have worked.
    What I did was hit the power button and then released and then hit and hold till the screen starts.
    This gets me into clockwork everytime on froyo and now on my gb.
    I guess it only works sometimes!
  4. #103
    Points: 744, Level: 14
    Level completed: 44%, Points required for next Level: 56
    draccocain's Avatar
    45131
    Aug 2011
    sacramento
    13
    this is f-in... great luv this droid only because of u guys and ur support without it i d b so lost m glad to b part of this thanx
  5. #104
    draccocain's Avatar
    45131
    Aug 2011
    sacramento
    13
    this wrkd great 4 me pwr crd pluged in pull bat went rght into clkwrk thanx! now m off to try out more roms
  6. #105
    Points: 1,421, Level: 21
    Level completed: 21%, Points required for next Level: 79
    3 months registered100 Experience Points31 days registered7 days registeredTagger Second Class
    power950's Avatar
    37916
    15
    my droid x would always go in clockworkmod recovery 2.5.0.8 after my batter died and i turn it on after getting to about 10% and it always went onto that idk if it was just something with mine but try it i used droid x recovery bootstrap from the market try it
  7. #106
    RKramden's Avatar
    17763
    31
    That is normal for Clockwork to come up first after charging your phone. It's designed that way so in the event you had to do a battery pull to recover from a bum ROM install or a bootloop you can then restore a nandroid backup without having to do a complete wipe &/or SBF. You actually should NOT let your battery die like that every day. There was an article regarding this and the short story is that unlike NiCads, these batteries don't have charge memory. You should only drain it all the way down about once every other month.
    SscoootzZ likes this.
  8. #107
    Points: 3,815, Level: 39
    Level completed: 10%, Points required for next Level: 135
    zekrom8686's Avatar
    39119
    6
    Exclamation Grrrrrr.....
    Quote Originally Posted by Abe21599 View Post
    i take it it worked for you?
    I am on the .605 kernel with MIUI ICS and CWM 5.0.2.0 and I have tried EVERYTHING!!!! Somebody please help me!!!!
  9. #108
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Have you pressed down at the blue light? Then recovery>latest recovery?
  10. #109
    zekrom8686's Avatar
    39119
    6
    Talking
    Quote Originally Posted by DirtyDroid View Post
    Have you pressed down at the blue light? Then recovery>latest recovery?Sent from my DROIDX using Droid X Forums
    Guy at XDA already told me. Thanks though.
  11. #110
    Points: 77, Level: 1
    Level completed: 54%, Points required for next Level: 23
    roderick5881's Avatar
    55119
    when I rooted my X it never went into recovery. Its seems to be rooted, because su and bootstrap are working, but I am not able to go into recovery mode. I'm trying to flash a ROM and it is just not working for me.
    I have messing with this all day and keep in mind I am still new to this.
  1. Can't boot into clockwork mod recovery
    By omnicious in forum Hacking Help
    Last Post: 12-25-2010, 01:44 PM
  2. CWM will not boot into recovery/backup
    By Eyefro69 in forum Droid X Hacks
    Last Post: 11-16-2010, 06:28 PM
  3. Replies: 3
    Last Post: 11-10-2010, 12:07 PM
  4. Replies: 5
    Last Post: 11-06-2010, 07:58 PM
  5. cant boot into recovery with rubix 1.0
    By wezley in forum Droid X ROMs
    Last Post: 10-23-2010, 08:31 PM
boot droid x into clockwork recovery
boot droid x into recovery
boot into clockwork recovery droid X
droid x boot into clockwork recovery
droid x boot into recovery
droid x how to boot into CLOCKWORK recovery
how to boot droid x into clockwork recovery
how to boot droid x into recovery
how to boot into clockwork recovery droid x
how to reboot droid x
