Droid X won't boot past M screen or into recovery mode
This is a discussion on Droid X won't boot past M screen or into recovery mode within the Droid X Rescue Squad forums, part of the Droid X Discussion category; Earlier today my droid x, was running slow so I did a power off to restart it. Usually do that every day or so. When ...
Thread: Droid X won't boot past M screen or into recovery mode
    Earlier today my droid x, was running slow so I did a power off to restart it. Usually do that every day or so. When I went to turn the power back on it would not boot past the "M" screen. No new or weird apps, it worked fine all day before this.
    I have tried to go into recovery mode with no luck. I have taken the battery out and let it sit for an hour then tried again with no luck.
    I have OTA 2.2, and I am rooted for wifi tether, nothing else.
    I've had the phone since launch day with no other problems until this randomly happened.
    I can get into the bootloader screen, but it is my understanding that I cant go back to 2.1 from OTA 2.2.
    Anyone, have any suggests on how to bring my X back to life,,, ahhhhh. I don't know much more than the basics about android.
    Thanks!
    Points: 1,824, Level: 25
    Level completed: 24%, Points required for next Level: 76
    Bajaman's Avatar
    20493
    63
    I'm a new DXer, one of the first things I did after rooting and deodexing, was learn the sbf process. I would think the best option would be to go get the 2.2 sbf and reload (it's very easy).
    Like I said, I'm new, so I would wait for someone else to validate my thought or give you the correct answer... if I'm off base.
    Good Luck!
    Points: 42,982, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,335
    786 times
    Boot into stock recovery. Push the power button and home button together. Release the home key when the M screen appears. Push the search key, then use the volume rocker to go down to factory reset, and push the camera button.
    Thats the problem, I cant get the phone to boot into recovery mode, even when I push the buttons it wont move past the M screen.
    I guess my question now is, since I cant get into the stock recovery is there any sbf I can reload over the 2.2 OTA to try and get things working again?
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,335
    786 times
    Yes just look for the link under hacking help
  1. Get Droid X in Charging Mode on Boot Screen
    By chavist in forum Droid X Rescue Squad
    Last Post: 12-15-2010, 10:47 PM
  2. Can't get past splash screen
    By Valle in forum Droid X Rescue Squad
    Last Post: 12-05-2010, 01:44 PM
  3. X won't boot past M logo
    By fragar in forum Droid X Help
    Last Post: 11-17-2010, 07:53 PM
  4. Replies: 10
    Last Post: 09-04-2010, 04:40 AM
  5. Please help. Droid X stuck on M, I can get to the recovery screen !
    By rkelly in forum Droid X General Discussion
    Last Post: 09-02-2010, 04:56 AM
Droid X won't boot
droid x wont boot
droid x wont boot into recovery
droid x wont boot into recovery mode
droid x wont boot past m
droid x wont get past m screen
droid x wont get past motorola logo
droid x wont get past motorola screen
droid x wont go past motorola screen
motorola droid x wont boot past motorola logo
