Cannot UNROOT Droid X! - HELP
So I recently ROOTED my phone using:
One Click Droid X Froyo ROOOOT GUI! - Droid X Rooting - AllDroid Public Board - One Click Droid X Froyo ROOOOT GUI! - Droid X Rooting - AllDroid Public Board - AllDroid.org > Home
And its suppose to be a once click Root and UnRoot, but I cannot unroot!
It always says unroot complete rebooting ADB but when its finished, its still rooted!
I've tried it in every USB mode like pc mode, windows sync, usb mass storage and charge only. Debugging mode is always on.
Please help, I do not need my phone rooted currently and Really Really want it unrooted.
Thanks!
EDIT:
So I think I fixed it, I used:
- open your trusty terminal app
- you should see a $ symbol, now do the following
- su
- now you should see a # symbol
- mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
- rm /system/app/Superuser.apk
- rm /system/bin/su
- rm /system/bin/busybox
- mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
- reboot your phone.
and the app is gone, and the $su no longer turns into a #
Any way to confirm?
11-08-2010 06:06 PM
If you want to go back to stock perfectly (like if you're returning the phone), go learn how to sbf it.
+1 with Jax, the best and most complete way is to SBF
