Has all downloads stopped working for you? Or has only downloads from one area stopped working? IE: Market, Browser, Aptoide, Apktor, etc. Well this happened to me last night and after much searching I never found anyone with the answer. Hopefully this post can help some people out.
First off, here is what I am running:
Phone:
Droid X - Rooted - Rubix Focused 1.0 - Incognito Red Blurless 3.1
Symptoms:
Downloads fail from different areas. Either browser, market, other places or all of them.
The problem:
- Downloads from the market will say, "Download started", but the progress bar will never move.
- Downloads from the browser will say, "Download Unsuccessful", after only a split second.
- Downloads from Apktor or the like will say, "Could not connect to the server!".
For some reason, you do not have permissions to write to your specified download folder.
The fix:
FOR MARKET DOWNLOAD ISSUES:
- Run Root Explorer (Or acquire it if you have not yet).
- Browse to the specified download folder. For the browser this is usually the "Downloads" folder on your SDCard. For Apktor-Aptoide it is usually the ".Aptoide" folder on your SDCard. For the market, there is a different fix.
- Once you have found your folder, tap and hold on it until the pop up menu comes up. Scroll down and tap on "Permissions".
- You'll probably find that the "User" account does not have write permissions (Maybe not read or execute either).
- Simply tap on and give the user read,write, and execute permissions to that folder.
- Exit and enjoy.
- Go into settings/Applications/Manage Applications
- Scroll down and select "Browser".
- Tap on, "Clear data".
- Tap on, "Clear cache". (Pretty sure its just data that you need. But might as well!)
- Exit and enjoy.
Suspected Cause of Problem:
My problem started after playing with, "ROM Manager". I was seeing what all it could do, saw the "Fix Permissions" option and ran it. I think that this is what cleared the permissions to my download folders.
***This might not be the cause of every download issue, but after all of my research, I could not find any other resolutions besides "Wipe the phone" or "return to verizon". I am also not saying that the ROM Manager app is bad, but maybe it conflicts with some settings I have. Perhaps the dev could check into this and see if it is incorrectly setting permissions.***
What next?
