Droid X Stuck at Tranquility Logo after trying to restore NANDROID backup :(
Hello everyone. I have a bit of a problem. My Droid X is frozen at the Tranqulity logo after I tried to do a NANDROID backup to restore my phone from Tranqulity Black 2.3.9 that I just recently installed, back to my default rooted stock 2.2 Android rom that was on there before. I noticed that with this particular rom, and the forum post about it, it says: Do not Wipe Cache/Data. It will get you stuck at the M logo. (Which in my case seems like the same stuck position, but the Tranquility logo instead), and I was to stupid to read the mini-guide thoroughly, and I wiped both of them before I installed it, and it installed fine, but I guess when I tried to restore, I wiped something it was missing when I cleared both of those things.
I tried getting it into bootloader mode so I could flash it with the 2.2 SBF, but everytime I took it off of the charger, and held down: the camera button, down volume button, and the power button for 2-3 seconds and released them, it looked like it was trying to go into bootloader mode, but all I get is a black screen that says something like: Battery too low to go into bootloader mode. And it has some number at the top, and from what I recall it starts with a "3" or something. Ive had it on the charger for just about 3 hours now, and its just sitting on the Tranquility screen still. Ive tried multiple battery pulls, unplugging it, and then trying to go into bootloader mode, but it keeps telling me the "Battery too low" message in white text with a black screen. If anyone has any suggestions on how to go upon helping me get my phone resurected, I would greatly appriciate it. Thank you in advance.
10-18-2010 09:50 PM
Well heres an update: Now when I do a battery pull while its stuck on the Tranquility screen, unplug it from the wall charger, and put the battery back in and try to push the key combinations to go into bootloader-mode, the little hole in the top left-hand corner of the phone (that usually illuminates green when the battery is completely dead and you plug it up to the wall to charge it) blinks dark purple/blue one time very quickly, and thats it. Sometimes I can wait a few seconds and press the same key combinations to try to go into bootloader mode again, and it blinks the same color, but only once. Im kind of confused here now, because it at least used to go into the bootloader mode and tell me the battery is too low, and now it just does this. Well I just thought I would post an update just in case that further explained more of maybe what is going on with my device. :/
Well, I was able to get a battery from a local VZW store, use that battery with a charge to get into the bootloader, and flash the phone with the SBF, and now my phone is fully functional. I think the battery I had was just so ran down, and because of that, it kept telling me "battery to low, cannot program.", and then it was so dead it stopped telling me that. Now ill return the battery I just bought, and get a refund. But anyways im good to go now.
LOL, you answered your own ?s/ solved your own problems
Although, yes when the battery is that low you are in trouble as you were.
