Is there anything special I need to do to install the 32GB card I just got from Verizon?
This is a discussion on 32GB Memory Card install? within the Droid X Help forums, part of the Droid X Discussion category; Is there anything special I need to do to install the 32GB card I just got from Verizon?...
Not really. What you should do is copy all the data on your current card over to your computer and then copy it back to the new card so you don't lose anything or start from scratch.
I just did this to my phone, worked beautifully. Put the 32gig card in the USB read it comes with, hooked the droid to the computer with usb, copied droid data to the 32 giger. Then I just unhooked the card reader and phone, turned off the phone, pulled the battery and swapped cards.
----------------------------------- + -------------------------------------DroidX (rooted) Liberty Rom 1.5 w/Revolution Remix Theme
-(Purchased 7-15-10 1st in at my local BB)-
I will never get or want an iPhone!
My wife said I spent too much time on my Droid.
So I bought her one. End of story...
5 Droid Family - Droid - Droid - Droid - Facsinate- Droid X
Hi guys...
I just bought this phone and went all out...and bought a 32.
I didn't know that I did NOT have to format the 32 just plug in and goooo....
anyhow...I did a format from the phone.
It came back w/ an error damaged memory card etc...etc.
I tried it again...and it wouldn't work.
I swapped back to the 16 and formatted without any problems.
Here is the kicker...
I plugged the 32 into the desktop and formatted...then plugged back into phone....and it works....
Then tried the reformat using the phone....the error pops up.
Before you guys say anything i thought it could be a bad memory card. I went to Verizon got a another memory card...SAME end result. Basically I cannot reformat a 32 using the phone.
Is this a software or hardware (phone) glitch/problem?
Anyone care to share?
Droid X is sold out....so i can't experiment w/other phones at the store. I was told by the sales rep this is a software issue.
Anyone Anyone?![]()
UPDATE: 32GB is in and working great! Easy as pie! Walked me right through the phone thing. Started taking musc OFF my busted iPod and putting onto my DROID X. With a 32GB ipod costing $300 and I got this card for $100 - no new ipod needed. SEE YA APPLE!
Best DROID X day since July 15th when I got the phone:
New 32GB card
OTA Update
LOVE THIS PHONE!
check my last post
