Hi, just curious if anyone has been experiencing the same or similar problem. All of a sudden as of Monday afternoon, my phone doesn't function the same. Now when I'm at work, it says I'm in Extended Network and I no longer have connection to the internet. Occasionally, the orange triangle with exclamation point shows up in my notification bar that says Data Roaming - stating that data connectivity was lost because you left your home network with data roaming?
I've tried all of the simple fixes: turning on/off, pulling battery, *228.
Does anyone have any ideas as to why this has happened? Or will it be fixed with an update? Did something happen to the towers over here? Is there something wrong with my phone?
HELP!
