Need 'Lil Help With Deodexing
This is a discussion on Need 'Lil Help With Deodexing within the Droid X Help forums, part of the Droid X Discussion category; OK, so I'm trying the 928DeOdex easy method ( 928DROID Releases Easy Deodox/Odex Method for DROIDX - Droid Life: A Droid Community Blog ) I ...
Results 1 to 2 of 2
Thread: Need 'Lil Help With Deodexing
    Balticzar's Avatar
    3066
    42
    OK, so I'm trying the 928DeOdex easy method (928DROID Releases Easy Deodox/Odex Method for DROIDX - Droid Life: A Droid Community Blog)
    I put the DeOdexEER.zip file on the root of the SD card and all goes swimingly until I have to find the blasted thing at the "select zip to install" step. It doesn't show up. Do I have to unzip prior to installing on the SD card? Do I have to rename the file extension? I can see the file when I'm in USB mode looking at the card's contents as a folder on my PC but it doesn't show up in Recovery mode on the phone. What gives? Thanks guys.
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    how does it appear on the sd card? update.zip ? make sure its also located on the root of the SDcard (not in any folders)
  1. Question about deodexing
    By supahrob in forum Hacking Help
    Last Post: 09-22-2011, 02:17 PM
  2. droid x deodexing
    By jurm0001 in forum Droid X General Discussion
    Last Post: 10-08-2010, 11:40 AM
  3. Nervous about deodexing
    By EdgeKrusher187 in forum Droid X Hacks
    Last Post: 10-04-2010, 11:33 AM
  4. Problem during DEODEXING
    By jbreezy in forum Droid X Help
    Last Post: 09-27-2010, 05:15 PM
motorola atrix deodox
what kind of sd card comes with a droid x
