ok I have a phone that I'm returning and had gotten root for the main purpose of getting titanium backup to back everything up.
I used that little program with the two buttons made by Silentkill to do the rooting procedure.
Backed up my stuff with titanium, then things went haywire with the sd card when i tried moving the apps to sd card (not sure why i tried that, but not sure why it didn't work either)...couldn't get it to mount as a drive over usb (though could look through it fine on the phone)...also it would hang every time I tried to uninstall apps.
Got the droid x bootstrapper by clockworkmod and did a factory reset...works fine now, except I can't get rid of the tools i used.
I can't get rid of root. I use the program to unroot, does it's little thing and has a progress bar, reboots phone.....STILL have superuser permissions in the app drawer.
Also, when I go to reboot the phone, i get that damn Clockworkmod Recovery menu every time. How do I get rid of it? Wouldn't a factory reset turn that off (not to mention root)?
I want to get rid of SU and the recovery menu so that when I turn it in, I don't get charged for the replacement because they thought i was 'tampering' with it.
