Typing Sound/Click Removal?
This is a discussion on Typing Sound/Click Removal? within the Droid X Help forums, part of the Droid X Discussion category; So I've tried every menu option to get rid of the clicking when typing a message....with no avail. Help?!?!?!?! It's really annoying to EVERYONE around ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Typing Sound/Click Removal?
    So I've tried every menu option to get rid of the clicking when typing a message....with no avail. Help?!?!?!?! It's really annoying to EVERYONE around me. Thank you!
    sherm's Avatar
    323
    19
    Hmm... mine doesn't make a noise when using the keyboard. I'm not sure where the setting is, though.
    Tagger Second Class500 Experience Points250 Experience Points100 Experience Points7 days registered
    baniels's Avatar
    30
    52556
    369
    25 times
    Go into the Language and Keyboard settings. From there you can manage the settings for the keyboards installed. Swype has it's own set of settings, as does the stock keyboard.
    Points: 5,523, Level: 47
    Level completed: 87%, Points required for next Level: 27
    Overall activity: 1.8%
    B360155's Avatar
    217
    North Richland Hills, TX
    383
    32 times
    From your home screen, hit the menu button (lower left). Click on Settings. Click on Sound & Display. 7th item is Audible Touch Tones. If it's checked, your keyboard clicks. If you uncheck, it's silent. Below that is another key Audible Selection. If that item is checked, then you'll also hear a different click whenever you hit a widget or icon. Actually, I kind of like having them on but I can understand how it could be annoying to co-workers.
    baniels's Avatar
    30
    52556
    369
    25 times
    That is not correct. You are describing how to remove the sound made when DIALING a number - Audible Touch Tones. The method in my previous is to remove the keyboard sound the OP was experiencing.
    Quote Originally Posted by B360155 View Post
    Quote Originally Posted by baniels View Post
    ok, tried it - thanks but no cigar. still clicks....even tried enabling and then disabling 'sound on keypress' under the multi-touch keyboard menu...
    help?
    baniels's Avatar
    30
    52556
    369
    25 times
    I don't suppose you're using swype, are you?
    i am .... at times.
    ok, figured it out... had to go into the 'swype' settings. thanks for the help!
    B360155's Avatar
    217
    383
    32 times
    OK, for the record, I use SKYPE also and checked the Language and Keyboard setting and it had Audio Feedback switched ON for the SKYPE keyboard. I'd only played with the Audible Touch Tone and Audible Selection switches under Sound & Display and if I uncheck both, I do not get any sounds on either the phone dialer or the typing keyboard, and it also grays out the Audio Feedback switch on the SKYPE keyboard under the Language and Keyboard setting, so it appears that at least on my phone, the Sound and Display choices will override the ones under Language and Keyboard. If I uncheck BOTH Audible Touch Tones and Audible Selection under Sound & Display, it does in fact silence both the phone dialer and typing keyboard.
  1. Ex-Blackberry Users Pls Sound Off!
    By jtdiddy in forum Droid X General Discussion
    Last Post: 01-07-2011, 09:12 AM
  2. Replies: 15
    Last Post: 07-25-2010, 05:03 AM
  3. Removal
    By dfdf332 in forum New Member Introductions & Site Assistance
    Last Post: 07-17-2010, 10:25 AM
Clicking sound when typing
Droid x typing sound
How to turn off keyboard sound on droid x
clicking noise when typing
droid x click when typing
droid x key sounds
droid x keyboard click sound
droid x keyboard clicks
droid x keyboard noise
droid x keyboard sound
droid x keyboard sounds
droid x turn off keyboard sound
droid x turn off typing sound
droid x typing sounds
droid x vibrate when typing
how to turn off keyboard sounds on droid x
keyboard sound droid x
swype clicking
turn off keyboard sound droid x
