factory reset
This is a discussion on factory reset within the Droid X Help forums, part of the Droid X Discussion category; when i do a factory reset just hit factory reset then after boot up skip all logins, activate phone, uncheck back up and auto restore, ...
Results 1 to 7 of 7
Thread: factory reset
    Points: 1,305, Level: 20
    zero66's Avatar
    3881
    47
    factory reset
    when i do a factory reset just hit factory reset then after boot up skip all logins, activate phone, uncheck back up and auto restore, then login to google? do i need to reformat sd or does it matter?
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,818
    138 times
    Only format the SD if it seems to be problematic.
    You will lose everything on the card if you format it.
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Points: 1,161, Level: 18
    Level completed: 61%, Points required for next Level: 39
    Overall activity: 0.0%
    debdado's Avatar
    7454
    Unhappy
    I have done a factory reset. I was hoping that would take my phone back to before it was rooted. It has not. Why is that? I am trying to take my phone from 2.1-version 1 rooted to 2.2 rooted. Can anyone help me to get there from here? I don't care how I get there. Please give me simple directions. Thanks in advance.
    I currently can't get the OTA update. It downloads but won't install.
    Backnblack's Avatar
    26
    2,818
    138 times
    You need to use the 2.1 SBF to get back to stock if your rooted.
    2. See Rule #1
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    Quote Originally Posted by debdado View Post
    you can (and pretty sure have to be) rooted to go from rooted 2.1 to rooted 2.2
    superuser and su are in the system. a wipe wont delete the apps
    hatemyEXlovemyX's Avatar
    6074
    520
    104
    Yes!! Factory Reset cleared all the issues I was having with FroYo! When I did the reset all my contacts were still there without their pictures and my photos in my camera had all disappeared. Everything when smoothly and I am much happier having to rest my phone n all.
    Sidekick II°•.Sidekick III°•.HTC 6800°•.HTC 8900°•.HTC Touch Pro°•.Blackberry Storm°•.DROID X!°•.
    Points: 4,788, Level: 44
    joeyjackpot's Avatar
    9452
    1,587
    84 times
    Factory Reset eliminates user data on the phone, but does not "restore" your phone to an "out of the box" state regarding System Files, which is what you mucked with when you rooted.
    You can upgrade to 2.2 from rooted 2.1 just fine. Your update won't go through because you deleted or renamed system .apks (bloatware) and the update will only go about 1/3 of the way on the status bar before saying "Update failed!" if it doesn't find all system .apks in place, installed, with the right permissions.
    You don't have to SBF - you can (while rooted) download and reinstall all the apks you removed - but since you're going to factory reset it anyway once you've upgraded, either one is just as much hassle so take your pick.
    Troubles installing OTA 2.3.340 Update? Click Here
  1. Factory Reset AFTER 2.2 OTA Update --- Do or do not?
    By anratliff in forum Droid X General Discussion
    Last Post: 09-19-2010, 01:51 PM
  2. Factory reset.
    By DolphinxManiax23 in forum Droid X Help
    Last Post: 09-19-2010, 07:26 AM
  3. Questions about Factory reset
    By bmosley in forum Droid X Help
    Last Post: 09-15-2010, 07:57 PM
  4. factory reset
    By buzzkill in forum Droid X Help
    Last Post: 09-12-2010, 08:24 PM
  5. Performing factory reset
    By alcar721 in forum Droid X Help
    Last Post: 08-25-2010, 10:22 PM
droid razr reset after 10 failed logins
