Sending/Receiving Calls: No audio once in call incoming or outgoing
This is a discussion on Sending/Receiving Calls: No audio once in call incoming or outgoing within the Droid X Help forums, part of the Droid X Discussion category; Searched the forums couldn't find anything related (although I may not have used the search function properly.) Had my droid for a little over a ...
Results 1 to 10 of 14
Like Tree5Likes
Thread: Sending/Receiving Calls: No audio once in call incoming or outgoing
    QuackVader's Avatar
    12496
    Had my droid for a little over a week (I'm new to the Android platform anyway so please be kind). Everything has been great until yesterday this started happening. When I receive or send a call, I can't hear anything out of the ear speaker, and the person on the other end can't hear me saying anything. I don't even hear it ringing when I call out. Speakerphone doesn't work either.
    I know the mic is functional because speech-to-text still works fine. All other audio works fine.
    Is this a problem anyone else has dealt with? I could easily take it back and replace it but I spent all week getting my menu screens the way I like them and don't want to deal with the hassle if there's an easy fix or something stupid that I can change in the settings.
    Edit: Just to get some simple troubleshooting out of the way, there's no bluetooth headset issue (I haven't even so much as turned on bluetooth yet) no hearing aid settings are on or anything like that. I turned off "voice privacy" and nothing changed.
    slwoods likes this.
    jpyounis1's Avatar
    10479
    68
    11 times
    Hey man. I had a problem like this a week after I got my phone. Try powering off the phone for a few minutes. Then turn it back on..after booting it should be fine.
    That's what I did and it went back to normal. I think the service or another app froze which caused it on mine.
    QuackVader and eromrab like this.
    Sheepdog's Avatar
    14006
    83
    I had the same problem with mine a week ago I just turned the phone off pulled the battery then turned it back on and havnt had that problem again
    QuackVader's Avatar
    12496
    I feel like an idiot now but thanks that did fix it. I had to leave it for a few minutes though, don't know why a few minutes would make a difference rather than 15 seconds but it seems to have done the trick. Thanks.
    Is there a difference between a "battery pull" and just a power down for a few mins?
    Sheepdog's Avatar
    14006
    83
    There shouldnt be a difference 15 seconds should be enough dont know why a couple minutes helped but hey what ever works and gets your phone back up and running
    Points: 986, Level: 16
    Level completed: 86%, Points required for next Level: 14
    chetqwerty's Avatar
    7079
    33
    Wow just happened to me too which is how i found the thread. Trying to find a cause, prob froyo, everybody else have froyo? never had the problem on 2.1 or the leak, hope the moto froyo fix comes soon.
    ataraxis4me's Avatar
    13378
    15
    Know the feeling so well! What I don't understand is that mine only does this when I get a call from my friend that has a Verizon pre pay phone. As I'm trying to answer him... and he can't hear me... I can get another call from someone else (my son on reg Droid) switch over to him and he hears me just fine! Is there something between the Droid X and this pre pay phone specifically? Sure seems so! I'd thought that buying the Extended Controls App did the trick... till today... and here I go again. Grrrrrrr!!!!! Sure hope someone has a real solution to this problem. Still in my 30 day period, but the thought of redoing all my apps and such is not a good one... especially if this is a software issue that a new phone won't solve.
    Points: 1,474, Level: 21
    Level completed: 74%, Points required for next Level: 26
    eromrab's Avatar
    15447
    11
    Smile
    Thank you soooo much! I just pulled the battery for about 15 seconds and it worked like a charm. I had tried rebooting before and that didn't work. Was starting to get all worried... So thanks!
    Oh, and yeah, this is the first time I've ever had this problem and I've had phone since they came out. I have 2.2 froyo. Could just be a froyo thing.
    31 days registered250 Experience Points100 Experience PointsTagger Second Class7 days registered
    CrashF16's Avatar
    815
    202
    18 times
    Happened to me this morning. A power cycle cleared it up.
    jpyounis1's Avatar
    10479
    68
    11 times
    I think its a froyo software glitch. Ever since the update it does it once a while..where as it never happened with 2.1. No buggy a power off reboot fixes it. I hope they fix this.
  1. Dx quit ringing with incoming call
    By Mr. Chumley in forum Droid X Help
    Last Post: 10-03-2010, 09:35 PM
  2. Problems sending/receiving texts; sometimes calls
    By coldcaption in forum Droid X Help
    Last Post: 09-23-2010, 06:57 PM
  3. Incoming Call ringtones don't work
    By margie harris in forum Droid X Help
    Last Post: 09-23-2010, 12:23 AM
  4. 2.2 broke incomeing and outgoing phone calls
    By sneakumlax in forum Droid X General Discussion
    Last Post: 09-22-2010, 03:33 PM
  5. Can't make outgoing calls
    By omnicious in forum Droid X Help
    Last Post: 07-26-2010, 07:04 PM
all volume on my gs3 is fine except for the voices of incoming callers... fix?
can not hear the call or caller on my droid pro
can't hear calls on my droid charge
cannot aanswer or hear calls on droid pro
cannot hear incoming or outgoing calls on android
droid dna cannot hear incoming calls
i can't hear anyone when i receive a call on my droid phone
milestone x no audio
no volume on android phone for incoming or outgoing calls
why wont my motorola droid make outgoing calls
