Text messaging faulty after 2.2 upgrade
This is a discussion on Text messaging faulty after 2.2 upgrade within the Droid X Help forums, part of the Droid X Discussion category; After the most recent upgrade for my Droid X whenever i receive a text message it does not appear at the top of the list ...
  • 1 Post By joeyjackpot
Thread: Text messaging faulty after 2.2 upgrade
    7 days registeredTagger Second Class
    thrillamilla's Avatar
    13756
    5
    After the most recent upgrade for my Droid X whenever i receive a text message it does not appear at the top of the list of people. It will usually appear 2 or 3 people down from the top. This was never a problem before the update.
    I have tried changing every setting in text messaging settings and nothing has worked. I have already had to do one factory reset for this phone and I really dont want to do another! Please help!!
    -Nate
    Points: 4,788, Level: 44
    joeyjackpot's Avatar
    9452
    1,586
    84 times
    It's a glitch in froyo - it's setting all incoming texts as GMT time zone rather than the one you are in - motorola is working on a patch. In the meantime, download SMS Time Fix (with the bandaid icon) from the Market and set the offset inverse to your timezone to fix until the patch comes along.
    For example, i am in Eastern Time Zone and with Daylight Savings I am GMT-4, so, inverting that, my offset is set to +4. You can find out what your time zone is by going to Settings>Date & Time and seeing what it says for your time zone. it will say GMT+/-#. Take that number and invert the + or -.
    thrillamilla likes this.
    13756
    5
    Your a life saver man, it now works perfectly! thanks much!!
  1. text messaging, received and sent
    By patenlaw in forum Droid X Help
    Last Post: 05-04-2011, 05:48 AM
  2. What is the best text messaging app?
    By Deluxe in forum Droid X Apps
    Last Post: 03-25-2011, 05:37 AM
  3. Slow text messaging?
    By jcarter1017 in forum Droid X Help
    Last Post: 09-04-2010, 11:40 AM
  4. Hep with Text Messaging
    By pblanton in forum Droid X Help
    Last Post: 09-03-2010, 06:51 PM
  5. Text messaging help
    By gregm311 in forum Droid X General Discussion
    Last Post: 08-19-2010, 11:41 AM
droid 2 texting glitch
droid x slow texting
droid x text message settings
droid x text settings
droid x texting glitch
droid x texting settings
droid x texting slow
slow texting droid x
text settings on droid x
texting on droid x slow
