How do I stop it from vibratting when I get an email
This is a discussion on How do I stop it from vibratting when I get an email within the Droid X Help forums, part of the Droid X Discussion category; More spcifically, how can you adjust the vibration setting for a synced email account?...
Thread: How do I stop it from vibratting when I get an email
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Hello and welcome!
    Are you using stock gmail? If so, you can change this in settings of the app...also, if you are using stock gmail, there is an app called gmail notifier that allows you some additional customization on the notification...
    Thanks, I'm actually having the most trouble with my corporate EMail, which I receive all day long. Its synced and actually I had to download touchdown to sync it because I have Verizon.
    20,509
    885 times
    I do not actually use an exchange account - however, I am sure someone will be along shortly to help ya that actually uses it...good luck!
    Points: 1,844, Level: 25
    Level completed: 44%, Points required for next Level: 56
    10forty2's Avatar
    8649
    95
    11 times
    Try opening the email account in which you want to change the settings. Press the hard menu button and select "Email Settings." Select "Notifications" and then which sound you want (or silent) and un-check the box beside vibrate.
    For Beautiful Fine Art Photography Please Visit:
    http://dougloganphotography.zenfolio.com
  1. Email App doesn't show me both email addresses
    By sinaweena in forum Droid X Apps
    Last Post: 09-28-2010, 12:16 AM
  2. How do you stop a download after 2.2?
    By XtremeXP in forum Droid X Rescue Squad
    Last Post: 09-25-2010, 02:50 PM
  3. Stop vibrating on new email arrival
    By droidxn in forum Droid X General Discussion
    Last Post: 09-16-2010, 07:45 AM
  4. Replies: 1
    Last Post: 09-02-2010, 03:38 PM
  5. Can't stop myself
    By carolnim in forum Droid X Help
    Last Post: 08-21-2010, 11:58 PM
how do you stop deriod phone from vibrating when you receive an email
how to stop gmail from vibrating
make touchdown stop vibrating
touchdown android vibration
touchdown disable vibration
touchdown email notification vibrate
touchdown email vibrate
touchdown stop vibrate
touchdown vibrate
turn off vibrate motorola razr touchdown for
