This is getting really annoying. I pull the phone out of my pocket to have the screen upside down. Not a huge problem, but it just gets on my nerves.
Can I change the axis it rotates in back to two like before the OTA 2.2?
This is a discussion on I want the screen to turn in only two directions, like before the OTA within the Droid X Help forums, part of the Droid X Discussion category; This is getting really annoying. I pull the phone out of my pocket to have the screen upside down. Not a huge problem, but it ...
A couple of apps (you can also turn off rotation on the phone but it will turn it off for both directions)....I have not used any of these but was just a quick search on appbrain.com - if you find one, report backas I am sure you are not alone...
Rotate Lock - Android app on AppBrain (this one is new, no ratings)...
Rotation Lock - Android app on AppBrain
Orientation Lock/Unlock - Android app on AppBrain
I will look into those, thanks so much
