Charging Battery
This is a discussion on Charging Battery within the Droid X Help forums, part of the Droid X Discussion category; Should i charge the battery fully before using OR fully drain it and then charge it? I am getting conflicting advice. Thanks...
Results 1 to 2 of 2
Thread: Charging Battery
    Charging Battery
    7 days registered100 Experience Points
    Champin4's Avatar
    345
    44
    With todays batteries it doesn't really matter..out of tradiion i drained it then charged it. People are reportig problems wig the droid appearing to disharge really fast unless ou reboot either way so whatever you wanna do really
  1. Battery stopped charging
    By Jaxidian in forum Droid X Help
    Last Post: 07-21-2010, 12:06 PM
  2. Charging issue and connectivity
    By SHWELL in forum Droid X Help
    Last Post: 07-17-2010, 03:41 PM
  3. Best method of battery charging/phone use right when purchased
    Last Post: 07-16-2010, 05:56 PM
  4. They turned the charging port upside down
    Last Post: 07-15-2010, 10:53 PM
  5. DROID X - Charging
    Last Post: 07-15-2010, 01:03 AM
drain droid x battery to 0 then charge fully
droid x battery charging
fully charge droid x battery
