HDMI Out Kills Display
This is a discussion on HDMI Out Kills Display within the Droid X Help forums, part of the Droid X Discussion category; Whenever I use the HDMI-out feature, either through the gallery or Real HDMI, the phone will not let me go back to using the regular ...
Results 1 to 8 of 8
  • 1 Post By gman
Thread: HDMI Out Kills Display
    Livin_Lovin's Avatar
    13393
    6
    Whenever I use the HDMI-out feature, either through the gallery or Real HDMI, the phone will not let me go back to using the regular display afterwards. It seems like it just kills the display, as I was able to disable the HDMI-out on Real HDMI through the bump feature and then re-enable it through bumping it again. I was wondering if there is some setting I missed somewhere that enables it to go back, otherwise, I have to remove the battery in order to restart the phone.
    Points: 6,141, Level: 50
    Level completed: 96%, Points required for next Level: 9
    250 Experience Points31 days registered100 Experience PointsCreated Album pictures7 days registered
    cruckus's Avatar
    9313
    290
    Are you using it with real hdmi with the root settings enabled?
    13393
    6
    No. I did not root my phone.
    cruckus's Avatar
    9313
    290
    Im rooted so im not sure how it works non rooted but did you get the new update?
    13393
    6
    I have the update as well
    cruckus's Avatar
    9313
    290
    Does it happen if you use the hdmi just to view photos and stuff without real hdmi?
    13393
    6
    It happens whenever I try to disconnect it, even when just outputting through the phone's default app.
    gman's Avatar
    4002
    254
    122 times
    Quote Originally Posted by Livin_Lovin View Post
    Welcome to the "suck" that is known as 2.2 on the Droid X. Its a REALLY BIG BUG in the interface between the OMAP-DSS driver on the phone and the MAPPHONE-PANEL display driver. The code in the kernel that turns off the LCD display when HDMI is turned on doesn't always seem to be able to turn the display back on and bring it out of sleep mode. And once it fails to turn the lcd back on the driver is dead to the world. In an upcomming version of Real HDMI I am going to make my app force a full phone reboot when it happens so folks aren't literelly left in the dark. But when the gallery app does it you are kind of stuck doing a battery pull.
    Its a kernel bug so the only people who can fix it is Motorola. And sooner or later everyone who is using 2.2 is going to have it happen to them using real hdmi or the gallery app. Have sent numerous emails into Motorola about it, offering to help them fix it as I have pretty much narrowed it down. But just get the same reponse from them of "Reboot your phone, reset to factory, etc..etc...etc)
    I mention the HDMI output bug previous over in another one of my posts Droid X Froyo a problem of a buggy Linux Kernel? where I listed it as one of the many kernel bugs in the kernel in 2.2. You can read the full post I put over on the motorola forum about it here https://supportforums.motorola.com/thread/38053
    Feel free to head over to the official motorola forums to cuss at motorola about it and maybe to help get it a bit more attention.
    Flintlock likes this.
  1. Real HDMI - Control HDMI Port on your Droid X
    By gman in forum Droid X Apps
    Last Post: 05-06-2013, 10:35 AM
  2. 6 Ft Micro HDMI to HDMI Cable for Droid X at Meritline.com for $6.99 w/coupon code
    By StaticFaction in forum Droid X General Discussion
    Last Post: 10-20-2010, 09:59 AM
  3. Micro hdmi to hdmi Adaptor
    By justin82 in forum Droid X Accessories
    Last Post: 08-26-2010, 03:28 PM
  4. Display not shutting off and no GPS fix.
    By LOTL in forum Droid X Help
    Last Post: 08-13-2010, 08:17 AM
  5. Contacts Display
    By Iria in forum Droid X Help
    Last Post: 07-20-2010, 11:50 PM
Droid x enable hdmi
android hdmi out bug
droid x hdmi off setting force close
droid x screen output
droid x turn on bump feature
free droid x hdmi output
free hdmi apps droid x
hdmi out app droid x
x display for hdmi output
x2 turn on hdmi
